 Start SLR adapter for m39 lens
kktra080 Posted - Feb 08 2015 : 12:45:25 PM
Hello dear forum members,
I wonder if anyone of you know where can I obtain an adapter to use m39 lenses on Start SLR camera. I have searched the web, even bought "unidentified soviet adapter" hoping it woul fit, but no success.
Starts seem to be quality made cameras, but with only one lens designed for it. I know the adapter wouldn't allow use of automated diaphragm and it would mean full manual operation, but still. Because Start is often referred to as Russian Exacta, I even searched the option of getting Exacta to m39 adapter, but no succes either.
Any ideas please?
Best regards to all,
Marko
32   L A T E S T    R E P L I E S    (Newest First)
Luiz Paracampo Posted - Feb 15 2015 : 12:56:46 PM
Thanks David for the leaflet
Great!
Luiz Paracampo Posted - Feb 15 2015 : 12:55:50 PM
Ok people read "Perehodnye i Udlinitel'nyie Koltsa"
or "Transference and Extension Rings" for Start Photocameras
of course Transference +to accept M39 thread.
the ring 5 makes Start câmera accept Zenit M39 lenses
RCCCUK Posted - Feb 15 2015 : 09:51:34 AM
Here is a copy of the instruction leaflet:-
http://www.ussrphoto.com/UserContent/1522015_Start1.jpg
http://www.ussrphoto.com/UserContent/1522015_Start2.jpg
David.
Jacques M. Posted - Feb 15 2015 : 04:10:20 AM
Yes, Luiz: 50mm for the Praktina.
I was only pointing the likeness between the "wide bright ring" quoted by Marko and this "Praktina/M39 adapter ring": I cite eBay.
Luiz Paracampo Posted - Feb 14 2015 : 7:32:22 PM
Praktina can't accept any adapter due its large distance flange/film plane
regards
Jacques M. Posted - Feb 14 2015 : 10:42:28 AM
Really I cannot say what is the large bright plain ring.
We can't see its back
By sure it not belongs to the set.
Perhaps an adapter Praktina/M39 like the one I had proposed at the beginning of the thread?
kktra080 Posted - Feb 14 2015 : 10:23:38 AM
Thank you David,
best regards
Marko
RCCCUK Posted - Feb 14 2015 : 02:14:04 AM
Hi Marko,
You are absolutely correct. The adapter ring is M39 NOT M42. Many thanks. I have edited the Wiki accordingly. I will check further as to whether this ring is original.
David.
Luiz Paracampo Posted - Feb 13 2015 : 6:43:28 PM
kktra080 Posted - Feb 13 2015 : 3:18:19 PM
Thanks Luiz,
given the fact that adapter to M42 lens could not be made, should the WIki entry on Start accessories be edited? I don't recognize the "wide bright ring" on the photos of the Wiki entry:
http://ussrphoto.com/Wiki/default.asp?WikiCatID=123&ParentID=3&ContentID=1483&Item=Start+Macro+Rings%2E
What is it?
Luiz Paracampo Posted - Feb 13 2015 : 2:35:10 PM
Marko a perfect buy. the rear "male" ring adapts all M39 Zenit lenses and give correct infinity
Although IT IS IMPOSSILE manufacture a M42 adapter. as yo see in the Diagram Picture I posted the tube dimention and câmera throat is only 40.5mm Tolerance X3
Impossible to fit a 42mm into a 40.5mm tube
kktra080 Posted - Feb 12 2015 : 1:10:31 PM
I have checked the wiki catalogue- the accessories section on macro bellows and extension rings created by David Tomlinson. But the images for Start camera rings are not like the ones Luiz posted or what I have ordered from eBay. The text also says that an adapter to m42 lens is included. Were there more than one set available for the camera? Especially the adapter to m42 puzzles me...
Jacques M. Posted - Feb 12 2015 : 10:31:55 AM
Bravo!
kktra080 Posted - Feb 12 2015 : 07:09:48 AM
Hi Luiz,
here it is:
http://www.ebay.com/itm/181656613179?_trksid=p2060778.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Regards, Marko
Luiz Paracampo Posted - Feb 11 2015 : 10:41:18 PM
Hello KKtra pls send the link of such rings
Regads
kktra080 Posted - Feb 11 2015 : 12:58:24 PM
No need to write to Rafael! Found a kit on eBay. I hope it works, on the photos it is exactly like the one Luiz posted.
Thanks friends!
kktra080 Posted - Feb 11 2015 : 09:06:17 AM
No problem Jacque,
I have made my share of mistakes, so I wanted to make sure this time and arranged to meet my fellow forum member Ziga. He offered to lend his Praktina lens to mount them to Start, to make sure. Now we don't even need to do that since Luiz made a brilliant clear case.
I have some accessories for the Start- a waist level finder and macro extension tubes, but I don't have the adapter. The one on Yuriy's (Fedka) site looks like a short macro extension, not an adapter. The thin ring on the second link Luiz provided is obviously what I need. I have never seen it before, even on a photo.
So I should be on the lookout for it. Maybe write an e-mail to Rafael at rafcamera...
Thank you both- Jacques and especially Luiz for making the issue resolved.
Marko
Jacques M. Posted - Feb 11 2015 : 05:30:16 AM
The register of the Start is 42mm, if I read correctly your scheme, Luiz.
The Praktina's is 50mm. Not the same, hence my error.
Of course, it is impossible to mount a 39mm SLR lens (45,46mm register) on a Praktina (or at least to focus at infinity). No impossibility on a Start with the proper adapter. Fedka's one, for example...
Sorry, Marko. And thanks, Luiz!
Jacques M. Posted - Feb 10 2015 : 8:27:06 PM
You are absolutely right, Luiz. A smaller Praktina type...
Marko, I hope you didn't order the converter!
Luiz Paracampo Posted - Feb 10 2015 : 8:14:09 PM
More pictures of Start M39 adapter
http://www.ussrphoto.com/UserContent/1022015_start tubo 1.png
http://www.ussrphoto.com/UserContent/1022015_start tubo 2.png
http://www.ussrphoto.com/UserContent/1022015_start tubo 3.png
Luiz Paracampo Posted - Feb 10 2015 : 8:03:49 PM
Jacques It is a praktina type ... but smaller
the http://fedka.com/catalog/product_info.php?products_id=278&osCsid=8c986166eae89baa8152bcf762d3aa81[
shows the two adapters male and female
see again http://t.hacquard.free.fr/site1/kmz_start_en.html
Jacques M. Posted - Feb 10 2015 : 3:35:58 PM
Luiz,
Fedka's ring seems only an extension tube, not a conversion Start/M39, by the description ??
Jacques M. Posted - Feb 10 2015 : 2:36:24 PM
So, Luiz, the mount would not be a "Praktina type", contrarily to what the Princelle says?
Of course, it would not be the first time.
But if I follow the Princelle:
See http://www.markerink.org/WJM/HTML/mounts.htm
Thickness of the ring: 50 - 45,46 = 4,54mm.
Of course, only if the bayonet of the Start is a Praktina one...
Luiz Paracampo Posted - Feb 10 2015 : 1:44:41 PM
its use can be seen at
Luiz Paracampo Posted - Feb 10 2015 : 1:27:58 PM
Luiz Paracampo Posted - Feb 10 2015 : 1:25:17 PM
another original extension tube and adapter for M39 can be seen at
Fedka
Luiz Paracampo Posted - Feb 10 2015 : 12:59:02 PM
here we have the Start mount dimenions
http://www.ussrphoto.com/UserContent/1022015_start soesdinie.png
From Zenit câmera Q&A
Luiz Paracampo Posted - Feb 10 2015 : 12:22:20 PM
ATTENTION Praktina ring does not fit Start câmeras
The only way is doing the adapter together a competent leathe professional.
the adapter is unique.
kktra080 Posted - Feb 09 2015 : 08:23:00 AM
Super, I'll order an adapter right now!
Merci beaucoup Jacques!
Marko
Jacques M. Posted - Feb 09 2015 : 06:50:51 AM
The Princelle says that the Start has a "Praktina type" bayonet.
So, certainly you can use directly Praktina lenses.
kktra080 Posted - Feb 09 2015 : 06:23:36 AM
Thank you Jacques,
I have checked the link for the adapter- is Praktina lens mount (breech lock type) the same as the one on Start camera? On the web I have found data that Start has unique mount. If the mount is the same, than one can even use Praktina lenses on Start camera wihtout an adapter?
Best regards, Marko
Jacques M. Posted - Feb 09 2015 : 04:32:50 AM
Hello Marko,
I think that would help:
http://www.ebay.fr/itm/Novoflex-Adapterring-Praktina-M39-PRALEI-/400845573309?pt=DE_Foto_Camcorder_Objetivanschl%C3%BCsse_Adapter&hash=item5d54420cbd
As far as I know, Start cameras were delivered with that sort of ring to use directly Zenit 39mm lenses. Of course, you will be in manual operation.
