 Russian FED "Stemar" Lens
Bull Halsey Posted - May 07 2009 : 3:14:20 PM
Hi All,
I've purchased a "FED Stemar" Lens and can use instructions as how I get the lens so it's horizontal on the body. I would assume there is a screw adjustment to loosen in order to rotate the lens in the proper alignment.
Any input would be appreciated.
Luiz Paracampo Posted - May 12 2009 : 7:49:10 PM
Yes only loose a bit. Do nor remove.
At first screw the set in the camera.
With a nail enamel mark the top.
Let it dry.
Remove the assy from the camera.
Lossen the screws.
Place the inner nucleus in the correct position.
Retight the screws.
Easy.
Good luck!
Bull Halsey Posted - May 12 2009 : 1:54:07 PM
Obrigado, Luiz.
I will follow your instructions. The screws are just loosened a bit and not to the point where they can be removed?
Luiz Paracampo Posted - May 08 2009 : 06:58:23 AM
Hello Bull!
Go to page:
http://www.novacon.com.br/h3comp2a.htm
Observe the 3 pictures with the lens in various positions
You have four big screws at rear and four smaller in the front.
Loosing them, we set te lens in the proper position.
It is a kind of "wafer type" construction lens.
Regards.
