| agfa100 |
Posted - Jul 24 2013 : 11:56:54 AM What size lens hood does the Fed 50mm 2.0 lens for the Fed S camera take? |
| 6 L A T E S T R E P L I E S (Newest First) |
| agfa100 |
Posted - Jul 25 2013 : 8:06:16 PM Chris,
I have listed the 100mm f 6.3 and I will list the 50 mm 2.0 as soon as I receive it. I have used Fedka before he is very good to buy from, I have not used him for repairs will keep that in mind. I like to tinker with things myself first but I am not crazy and take my time and if I cannot figure it out I leave it alone. I never want to make anything worse.
Thanks wbill |
| Niko80 |
Posted - Jul 25 2013 : 4:59:26 PM Bill, the Fed 28mm f 4.5 is not as rare many people believe, I have 2 now. Just check ebay regularly, they sell for about 300-400$.
If your lens needs some repair you can send it to Yuri from fedka.com I've had all my lenses cleaned and collimated for my FED-S camera, they work great now.
Could you please add the serial numbers of your FED lenses to the wiki - or post them here?
Regards, Chris
| agfa100 |
Posted - Jul 24 2013 : 8:42:21 PM Thanks everyone, I have a extra Fed a-36 hood that black rubber/plastic one so I will be set when my lens shows up in two weeks. I only hope the front lens element is not too badly marked. Now all I need to do is win the lottery and find a Fed 28mm f 4.5 or one of those 50 Macro lenses. I have a Fed 50 3.5, Fed 100mm f 6.3 1st version with the pins and now a Fed 50mm 2.0, I use them on a Ricoh GXR with the A12 M module. I had a harder time finding two of the A-36 push on lens hood then the lenses, everyone had the a-37 style for the rigid 50mm f3.5 lenses. I got lucky with the 100mm it was clean and the focus is smooth, the only issue is the F stop ring has just a tiny bit of wobble too it. The 50mm 3.5 I just had to take apart and clean and relube the focusing mount. I have more fun using my old Russian lenses then with my M lenses, all my leica friends think I am crazy.
wbill |
| Niko80 |
Posted - Jul 24 2013 : 6:30:29 PM You should be able to use the Leica Summar lens hood SOOMP, but I guess a variety of 36mm hoods should fit.
You might want to take a look here: http://photo.net/leica-rangefinders-forum/00Bjwy
Regards, Chris |
| Luiz Paracampo |
Posted - Jul 24 2013 : 6:08:52 PM exactly push on 36mm Regards LP |
| agfa100 |
Posted - Jul 24 2013 : 12:23:58 PM Does it take a push on 40mm hood???? |
