| RCCCUK |
Posted - Apr 05 2014 : 02:12:06 AM According to J L Princelle, when the Zenit-E was first produced it did not have an instant return mirror. I have two early Zenit-E cameras, but both have instant return mirrors. Has anyone seen a Zenit-E without an instant return mirror, and if so what is the serial number?
David. |
| 9 L A T E S T R E P L I E S (Newest First) |
| Zoom |
Posted - May 22 2014 : 05:47:05 AM quote: Originally posted by Guido Studer
Do you have better sources?
I have! GOST 10332-72 and GOST 10332-63 http://www.zenitcamera.com/qa/qa-gost10332-72.html http://www.zenitcamera.com/qa/qa-gost10332-63.html
P.S. If anyone thinks that 45.5 mm is only in a Russian standard, please refer for example to: http://www.zenitcamera.com/archive/lenses/flektogon-2-8-35-adb-lk.tif
P.P.S. About a history of "45.46 mm" see http://www.zenitcamera.com/archive/history/mounts.html#n1
| Luiz Paracampo |
Posted - May 10 2014 : 6:42:27 PM Guido Alex is right according to original KMZ data, although difference is too little to be noted is most cases. Regards LP |
| Guido |
Posted - May 10 2014 : 2:21:24 PM Hello Alex
My sources say 45.5mm or 45.46mm (add film thickness and you will get 45.50mm):
http://www.graphics.cornell.edu/~westin/misc/mounts-alphabetical.html http://en.wikipedia.org/wiki/Flange_focal_distance
And in the first list you will even find a entry for the Zenit 3M (with the same mount as early Zenit E/B).
| Alex_Rus |
Posted - May 10 2014 : 1:42:50 PM Early Zenit E and B have M39 mount and the flange distance 45,2mm |
| Guido |
Posted - May 09 2014 : 3:43:16 PM Hello Milo
Well, in german the double negation is an affirmation, BTW. But that's not the point.
Early Zenit E and B don't use the M42/1mm mount, but a M39/1mm mount, that's true. But the flange distance (distance between lens mount and film/sensor) was the same as on M42, will say 45.46mm (and not 28.8mm like on M39/LTM). Small adaptor rings from 39 to 42mm where used to adapt early Helios-44 lenses to later Zenit E/B. I own some of this stuff but only one Zenit E with M39 mount; there are quite rare and most of the sellers don't even know about this.
| Valkir1987 |
Posted - May 09 2014 : 2:58:09 PM quote: Off-topic: Is it correct to write "there isnīt any Zenit E known" or should I have said "there is any Zenit E known"?
Both sentences seem to be correct, though the last question is better. If someone asks me "don't you want some coffee?" and the answer is yes... I would not get my coffee if the sentence was taken literally.
I don't know how common it is in other languages to ask denying questions, but they might be confusing.
On Topic: I don't think a Zenit E without instant return mirror existed. The new model was designed to have one. Early models are sometimes found with the old Leica tread mount. |
| daniel |
Posted - Apr 07 2014 : 05:05:27 AM The book in German by Alexander Schulz (http://www.g-st.ch/privat/kameras/zenitbuch.html) also quotes this information by Princelle, but admits that there isn't any Zenit E known without instant return mirror.
Off-topic: Is it correct to write "there isnīt any Zenit E known" or should I have said "there is any Zenit E known"? |
| RCCCUK |
Posted - Apr 06 2014 : 02:23:14 AM Thank you very much for your reply. As your camera is number 62, I think we can be pretty sure that all production Zenit-E cameras did have an instant return mirror.
David. |
| levonsa |
Posted - Apr 05 2014 : 2:31:19 PM Good evening David! I have a number of very early Zenit-E #65000062. http://www.ussrcameras.ru/?rp=1&action=tovar&tovar_category=141&id=356 This camera have instant return mirror. Maybe J L Prinselle knows even earlier versions? |
