cedricfan |
Posted - Apr 02 2009 : 1:26:06 PM http://www.ussrphoto.com/UserContent/Rubin11M.jpg
Works and focuses on M42-cameras, but fixed f:8 aperture. Any idea what on earth is this used for? TV-lens?
Best regards, Juhani
16 L A T E S T R E P L I E S (Newest First) |
cedricfan |
Posted - Apr 22 2009 : 03:15:54 AM This lens has no possibility to mount filters in the camera end, the rear element is approx where the RUBIN-11M text is, and there is only hollow tube inside mount. But if this is a movie/TV lens then it would not need the thread as filters are mounted in those large hoods. And the very small change in lens total lenght during focus would be no problem either. |
Poolhall |
Posted - Apr 22 2009 : 02:50:30 AM My Variozenitar 25-45 has a standard 58mm filter ring, serial 020082
Samsung GX-10,too many Russian Lenses, A lot of Zenit, some Yashica,and a Pentax Body also finally a Minox35GT |
Luiz Paracampo |
Posted - Apr 21 2009 : 9:18:36 PM Juhani The lens cap is original Bur do you remember the Vario Zenitar 28-45? It uses out of standard special filters. Regards LP
cedricfan |
Posted - Apr 20 2009 : 12:47:37 PM The promised close up showing filterthreadless front, lenscap groove and short travel focus ring.
http://www.ussrphoto.com/UserContent/Rubin11M_front.JPG
cedricfan |
Posted - Apr 17 2009 : 08:36:01 AM Lens is now at home, and now I am really puzzled!
First of all, it looks really odd, not like the cheap chinese & korean do with fancy text and many colours in engravings. This is very dull, like for some special work. The front ring has no text at all, and no filter thread. It does have that assembly ring, so filter thread is only left out. The lens cap has KMZ-logo. You say it can be from any lens. But this is the odd middle size: not for 52mm nor 49mm filter sized lenses, but in between! And fits perfectly. So no usual cap fits this lens... The lens is all metal, and heavy! No signs of plastic nor rubber, even focus & zoom rings are knurled in metal! And it is very thin, making it again odd, not something that would sell well. Zoom is internal, no effect on lens lenght or rear element placing. Not a cheap construction if I am correct. Focus ring "INF." and only 90 degrees to 1,2 meters, very fast action. No serial, no country, and the aperture is fixed 8. All text is also in picture (but closest focys 1,5)
I will take more pics when I arrive from Tallinn, but now I would say this is for some special use, like TV?
cedricfan |
Posted - Apr 13 2009 : 09:01:11 AM I will have more specs of this lens next week when it arrives, the price was decent enough to buy it. |
Zoom |
Posted - Apr 13 2009 : 07:05:15 AM quote: Originally posted by Luiz Paracampo
Zoom To clarify everything: -Why there are no "M" lens on M39x1?
Because there were no diaphragm authomatic on that time cameras. |
Luiz Paracampo |
Posted - Apr 09 2009 : 06:39:41 AM Zoom To clarify everything: -Why there are no "M" lens on M39x1? LP |
Zoom |
Posted - Apr 08 2009 : 08:05:17 AM quote: Originally posted by Luiz Paracampo
We are saying the same through different languages: Are there Zenit "M" lenses without tread mount?
No. But "M"-index is not an indication of M42x1 ;)
I like a clarity, certainty and exactitude, and a theory of sets. ;) |
Luiz Paracampo |
Posted - Apr 07 2009 : 7:37:54 PM Yes. But "M" is an indication of this diaphragm type, not to a thread. Only the "2" index is correspond to the M42x1 thread mount directly (for example: "Helios-40-2"). "K", "B" ("Á"), "V" ("Â") and "N" ("Í") -- to the bayonet mounts. "A" -- is the "adapter type mount" (usually to: M39x1/45.2 and M42x1/45.5) "C" or "Ts" ("Ö") -- with the central shutter (ZENIT-4, -5, -6...). _________________________________________________________ Dimitri: We are saying the same through different languages:
--"M" is an indication of this diaphragm type _Are there Zenit "M" lenses without tread mount? - --"2" -No discussion. --"K", "B" ("Á"), "V" ("Â") and "N" ("Í")- OK but "B" ("Á"), "V" ("Â") are for 6X6 cameras- --"A" - Also includes "K" and and "N" ("Í")adapters --("Ö") - Are completely different mount system.Diaphragm and depth of field scales on camera body. Regards LP |
Zoom |
Posted - Apr 07 2009 : 09:02:40 AM quote: Originally posted by Luiz Paracampo
All Zenit "M" lenses I know are M42x1 with pressure pin diaphragm activation.
All this descriptions are there: http://www.zenitcamera.com/qa/qa-indexes.html
Luiz Paracampo |
Posted - Apr 05 2009 : 6:54:31 PM Zoom All Zenit "M" lenses I know are M42x1 with pressure pin diaphragm activation. Do you know another? "K" correspond to K mount and translation pin. LP
Zoom |
Posted - Apr 03 2009 : 12:23:25 AM quote: Originally posted by Luiz Paracampo
the "M" the standard of M42 from Zenit heritage.
Nope. Index "M" is a type of a diaphragm mechanism. See (in Russian): http://www.zenitcamera.com/qa/qa-indexes.html#m http://www.zenitcamera.com/qa/qa-diaphragm.html |
cedricfan |
Posted - Apr 02 2009 : 11:17:49 PM This is all I know at the moment, but let's see next week... Would fit well my Helios-zoom-collection! |
Luiz Paracampo |
Posted - Apr 02 2009 : 10:18:30 PM Of course an interesting lens... at least different... Appears well made and compact. a very good range of demultiplication ..4 X ... The name "Rubin" picked from the first Soviet photo camera zoom lens The "11" picked from the most common .. Granit 11...or double 1 from Rubin 1 the "M" the standard of M42 from Zenit heritage. The diaphragm never fails once does not need any coupling to the camera...... The power Zoom also is infallible ...and wastes no batteries.. Perrfectly ecological for those days... once you do the power on your hands.....Any details on Construction?.. Quality?
Zoom |
Posted - Apr 02 2009 : 4:47:10 PM quote: Originally posted by cedricfan
This is not the Russian production. China?.. South Korea?.. I don't know. But looks like an "industrial fake". Why fake? Because "M", but as you saw, it aperture is fixed. |
