mermoz37 |
Posted - Feb 22 2008 : 10:22:10 AM hi all....what's that ?
[img]http://www.ussrphoto.com/UserContent/IMG_3672. |
18 L A T E S T R E P L I E S (Newest First) |
Luiz Paracampo |
Posted - Feb 25 2008 : 7:11:39 PM Allain Many thanks in advance. It will be needed only 75 dpi once they will only useful for internet You can send to my mail mariarnobre@terra.com.br I will be glad and honoured if you want to add your own comments. Salutations! LP |
mermoz37 |
Posted - Feb 25 2008 : 07:48:45 AM hey Luis, what kind of pictures do you want ? what size (300 dpi ?) , what details ? and how to send to you ?
note : mecanism is as fine as in a sewing machine !!!! and so heavy (aprox. 1.5 kg !!!!) |
nightphoto |
Posted - Feb 23 2008 : 8:27:19 PM Very nice Alain! I have not seen it before. Vlad may be correct that it is a precursor to ZOLA, since the lens has a date of 1966, at which time Zorki 6 was new, but Zola was not yet made until 1970. No doubt that for some surveillance a 35mm negative or transparency would have been much better than 21mm! So in a sense this may be a Zola prototype that was successful, did not need to be quiet for the kind of job it was intended, and then was developed into Zola.
Luiz Paracampo |
Posted - Feb 23 2008 : 8:13:15 PM Allain! You are fantastic in bringing to us such pieces! I carefully noted the beast and will describe it, A conventional Zorki 6 (with self timer and rangefinder!- Impossible of being used) is mounted in a large plate through its tripod bush. This camera aparently lacks multiple speeds on the dial and film indicator on the rewind buttom. The Zorki 6 is mounted with a modified production run wide angle Orion 15 with no focusing helicoid nor diafram control. According to the pictures the diaphragm is fixed at f 6 (the original maximum aperture)-has diaphragm blades but inoperative. The engenious thing comes now! --One to take the picture, opens the lock and gives 4 pressures on the bottom right side of the bag; this advances the film; when it becomes hard the film is advanced. One pressure on the left down side fires the shutter. Excelent for Museum pictures where pictures are forbidden! My Suggestion to Allan! If you could give us greater pictures it will be great to put this apparatius in my Oddities Page! Merci Allan! Mes Meilleurs Souhaits!
AidasCams |
Posted - Feb 23 2008 : 3:35:53 PM Fantastic item ... I like it a lot!!! |
Posted - Feb 23 2008 : 11:32:30 AM I really doubt KGB had used this, since they had much more efficient cameras for these purposes... I would suspect it would be either MVD or some other division of Militia.. very possibly this was also made for private use....
okynek |
Posted - Feb 23 2008 : 11:13:46 AM I wonder who made this contraption. KGB workshop? I would imaging that for KMZ will be easier to modify camera then make all this heavy attachments. And I believe KMZ engineers would came up with more elegant solution for such job. It seems that this devise would be very hard to use on the fields. And change film on the fly. And sound of shatter is not exactly stealthy. And limitation of only 36 frames. And weight of all the heavy metal. (ironically:) Poor KGB officers have to risk they own life to catch they own people using such mechanical wonder  Absolutely incredible item for collection though!!!
mermoz37 |
Posted - Feb 23 2008 : 10:18:56 AM mecanism ...from Ukranian "services" (KGB ?)
Posted - Feb 23 2008 : 10:15:54 AM Weeeird!!! .. A Zola predecessor? Is it? |
mermoz37 |
Posted - Feb 23 2008 : 10:13:13 AM and the strange wide angle lens....coming from ???? 35 mm movie cam ???
mermoz37 |
Posted - Feb 23 2008 : 10:08:54 AM looking inside....
Michel |
Posted - Feb 22 2008 : 1:45:27 PM I think I've seen this before……… Didn't I, Alain ??
Posted - Feb 22 2008 : 11:52:32 AM Gotta be one of the Ayaks covers... not sure which one until I see inside  |
mermoz37 |
Posted - Feb 22 2008 : 11:48:19 AM indication: ah ahh ahh ahh (cavern reverb laught
detail (and more after....just say ext size is :25x38 cm)
Jacques M. |
Posted - Feb 22 2008 : 11:26:49 AM
  With Alain, we can expect everything...
Jacques. |
Posted - Feb 22 2008 : 10:39:03 AM hehe.. a Zola bag? |
Luiz Paracampo |
Posted - Feb 22 2008 : 10:36:09 AM What is that a guessing play? |
mermoz37 |
Posted - Feb 22 2008 : 10:23:21 AM  |
