 zorki "standard" !!!
mermoz37 Posted - May 30 2008 : 05:50:58 AM
look at that, friends....
http://www.electricedge.com/gordon.coale/photography/equipment/35rf/index.htm
9   L A T E S T    R E P L I E S    (Newest First)
dgillette4 Posted - May 31 2008 : 12:40:03 PM
I almost forgot to tell you that I covered the cover with some leatherette I had...Don
ZORKIE'S Survive
dgillette4 Posted - May 31 2008 : 11:35:46 AM
No I kept the rangefinder and housing for spare parts, baffled off the holes and filled then mounted accessory shoes. The shroud for the shutter pin-hole timer I made from a housing for an automotive flasher module. I then remounted the spring from the shutter arm. It was attached to the base for the original cover and accessory shoe screws. I allowed room to access shutter pivots on the top for lubing. I always thought the Leica 1A was sharp so now I almost have one. Just Zorki Chrome will stay for now...The camera is pretty easy to work on except for doing a shutter re-do, then I will send it to Yuri I don't have that much confidence in doing re gluing them . These cameras are such a bargain, I am going to purchase another for back-up. Don
ZORKIE'S Survive
Vlad Posted - May 30 2008 : 10:05:46 PM
Don wow pretty cool! So did you just cut off the rangefinder housing? And what is it around the shutter release button?
dgillette4 Posted - May 30 2008 : 9:32:45 PM
The top is a Zorki original, The accessory shoes I had. I put the turrret viewfinder on and go shooting with my 35 jupiter. The hyper-focal focusing works great with the 35mm or wider. Don
ZORKIE'S Survive
Jacques M. Posted - May 30 2008 : 4:14:11 PM
That time, the body is the one of a Zorki.
Congratulations for the two accessory clips! And for the work...
Vlad Posted - May 30 2008 : 1:55:45 PM
Did you use a Leica standard top?
dgillette4 Posted - May 30 2008 : 1:53:22 PM
The hardest part was making a shroud for the shutter cam mechanism, relocating the spring anchor was the next time consumer. I saw a shutter shroud advertised at dag parts but they wanted $50 way too high. Don
ZORKIE'S Survive
http://www.ussrphoto.com/UserContent/2008_0530Image0001.JPG
mermoz37 Posted - May 30 2008 : 12:45:02 PM
Nice "do it yourself " Don !
may be i will try to make someting like that.....but i rack my brains to found another pattern
Jacques M. Posted - May 30 2008 : 07:06:51 AM
Hi Alain,
Why not....
But he could have used a real Zorki release button instead of the one of a Fed 1g...
I don't know why, but the vulcanite too looks to me from Fed and not Zorki...
