Smena goes digital!
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=1035
Printed on: 10/24/2026 6:23:50 PM
Topic author: cedricfan
Posted on: 20090107151040
My latest crazy idea [:o)]
We have an extra tiny Canon Ixus, and I would like to shoot digital with an old looking FSU-camera. So why not take a Smena and cut it so that the Ixus can be fitted into it [:p]
I have done some measuring, and the best body donor would be a Smena-8, but I am afraid that the hard bakelite can crack when cutting? Or can I cut it with a Dremel? Anyone ever tried? Or do I have to try and possibly ruin one of the zillion manufactured?
Next one is 8M, but it looks too dull, not FSU-like enough [:I]
And hardest to fit is Symbol, as the body is not thick enough. But looks OK [;)]
Just so that you get the idea, it is not impossible sizewise:
http://www.ussrphoto.com/UserContent/SmenaDigi.JPG
http://www.ussrphoto.com/UserContent/SmenaDigi.JPGNaturally I have to add two pushbuttons on top for ON/OFF and release, but that is not a hard thing to do. Zoom I can leave out, this Ixus has only 2x zoom and I can do with a fixed 38mm equivalent.
All other controls are in the back, so I will cut a large opening in the Smena back cover and case to get access to them.
Smena lens & shutter I will disassemble away.
Replied on: 20090107152419
Reply author: AidasCams
Replied on: 20090108010846
Replied on: 20090108035635
Well, if I am insane then Aidas is beyond any help [:o)]
What camera is it inside?
Replied on: 20090108052935
Replied on: 20090108091202
[:0][:0][:0][:0] Oh boy! This is completely crazy, hehehhehehehhe! Very cool though! Didn't think anyone would actually attempt it.
Replied on: 20090108095844
Now I will HAVE to make mine, no going back [}:)]
Replied on: 20090108103624
I am curious on how they managed to connect that mode dial on top to the camera inside.. very interesting... Everything else is more or less easy.
Reply author: mermoz37
Replied on: 20090108114359
that's seemed to be easy : just a thick rubber whasher ...isn't it ?
Replied on: 20090108115752
So you think it's mechanically connected? They didn't move the electronics contacts out to the top?
Replied on: 20090108153838
tomorrow morning i will place here the rest photographs I have of particular "digital" Smena [:)]
Best Regards,
Replied on: 20090109011424
Replied on: 20090109071501
nice work indeed ...must be fun on other common cameras .
Replied on: 20090110131137
wow!! The Smena body is completely altered! Someone did an excellent job on it! AND It has the LCD on the back! [:)] really nice work indeed!
Replied on: 20090224111059
Some major drawbacks...
The original idea of using Smena-8 will have to be postponed, the smell of cutting the hard plastic is so terrible that it needs to be done outside!
Plan B was to use an 8M body, but I haven't got the donor. Seems that pre-1990 were with hard inside and later ones with soft plastic inside. And my usual version is old, hard plastic. The later ones suitable for cutting are special versions, so I won't use them!
Now I will search a cheap normal version of later 8M and then we go further!
Replied on: 20090304145224
Reply author: chrgod
Replied on: 20090310094424
Cool work!
I am thinking about a home made digital back for a Kiev 88.. But this seems like a much easier starter project!
Keep it going! :)
Replied on: 20090310100455
Wow nice job Juhani! Somehow I missed your post.. Show us the final piece when you paint it, right now it does look a bit rough [:)].
Christian - LOL! You can file down the Hasselblad digital back to fit the Kiev, but it'll cost you about $20,000 to do that [:D].. 6x6 sensor is quite amazing.. with such a long body I have no idea what small pocket cam would even be able to get correct focus if mounted on the back.. this reminds me of a thread here from some time ago that someone mounted a flat bed scanner on the back of a wooden view camera to scan the glass thus getting like ridiculous resolutions of an excess 30MP.. [:D].
Replied on: 20090310100557
Replied on: 20090310143635
Replied on: 20090310144552
hehhehehehehe.. nice! [:D] I give you an "A" for creativity! [:D] The best part is that you can change backs [;)]
Replied on: 20090311070722
Excellent in every sense but the front finishings where we have the lens deserves a better appearance.
