Cutting bakelite?
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=1049
Printed on: 10/23/2026 8:01:21 PM
Topic author: cedricfan
Posted on: 20090111150932
So, I have decided to try making the Smena-digi from a bakelite "8" as it looks so lovely oldish.
But has anyone here ever tried to cut bakelite, eg with a Dremel? I know it is OK to slowly drill a tiny hole into bakelite, but cutting?
Replied on: 20090111152633
Juhani, I don't think the Smena-5 to 8 are Bakelite, these are just plain hard plastic..
Reply author: mermoz37
Replied on: 20090112041004
yes, they are unbreakable hard PVC or else plastics, easy to cut (but not to glue !!!)
Jauni abot bakélte : if you have to do that : cut whith hight speed tool (dremel or jig saw)
I often use metal cut saw whith small teeth.
Reply author: dgillette4
Replied on: 20090112102228
Hello Juhani: If it is Bakelite wear a dust mask when cutting ,the dust is hazardous to lungs. I too would use a dremel. I would love to see the results. Don
ZORKIE'S Survive
Replied on: 20090112103146
Guys,I think the only ACTUAL bakelite Soviet cameras are Turist, Liliput, Maliutka, Original Smena. Pretty sure everything post-war is just plain plastic. Am I mistaken?
Replied on: 20090112121150
Tomorrow I will get a pack of new cutting discs for my "Dremel", so let's see what happens [:D]
And naturally there will be pictures of the process and of the camera when ready [^]
Replied on: 20090113041705
Junkor ?
also to cut plastics or balélite : the best way is to stick a scotch tape , draw and then only cut trought scotch tape to avoid dust and shattering
