Zorki 3 slow speed lock question
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=1122
Printed on: 10/24/2026 12:28:18 AM
Topic author: uwittehh
Posted on: 20090303125909
one of my newest finds is an early Zorki 3 (serial starts with 0 and is on the top housing) with a slow speed dial that has this lock.
How does this lock work? For me it seems to do nothing :-) Should it lock the speed dial at 1/25 position normally?
By the way, as I have found out on Aidas site it's a Zorki 3 type 1e. Somebody has installed new shutter curtains and it is in a good state, slow speeds are correct.
Replied on: 20090303165011
That is true! First Zorkis 3 began with Zero. A friend of mine has onein his collection with a very low number. Special characteristic: the rangefinder main window is amber tinted! I have never seen another one like that!
The small ball locks the low speed dial.
Replied on: 20090304032027
Hi Ulrich,
On my 00707 (what a plane!), the lock only marks the speeds by clicking, from 1/25th (1/2th, 1/10th, 1sec) to B. And it prevents from going in the wrong way: there is a stop between 1/25th and B.
BTW, that's a curious range: I always wondered why KMZ used it...
About the viewfinder, mine would be rather mauve tinted (the same on my #5571252 3M).
Replied on: 20090304154120
Jacques and Luiz,
hm, I wonder a bit about that lock. On the Zorki 3 which don't have the lock, you also are not able to switch in the wrong direction. On my early one it does not lock the dial, it just looks good. And it clicks a bit more louder than on the one without the lock ball.
Replied on: 20090304161806
Of course, you are right, Ulrich...
It's the same with or without lock: I have just checked on another Zorki 3.
So, I don't know!
