Latest known FED 1d?
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=1290
Printed on: 11/22/2026 6:55:00 AM
Topic author: uwittehh
Posted on: 20090711121714
which is the latest known serial number of a FED 1d you know? As we know the FED 1e or Berdsk starts around number 175.000. I have a FED 1d with serial 169520 here. The lens has a matching number that is very close to the one of the camera.
There are two things that make it different to my other 1d's: The pressure plate hasn't the hole in it and it is totally round, and the lens cap has the FED name very deep stamped in and not more engraved.
Replied on: 20090711143009
Hi Ulrich!
Not easy to answer your question!
The eBerdsk begin at serial c. 173600. But there are some NKVD d type too among these numbers up to c. 176xxx. I saw several of them, and Alain possesses one of these very late d type.
As for the pressure plate, they are without hole from c. 15xxxx, if I am not wrong.
Replied on: 20090714161745
Hello Jacques,
thanks for your answer. I see it's so different as with all sowjet cameras :-) I have never seen a 1d with such a late number so I got it. And by the way it is in a real good state after CLA'ing it, it cocks really easy and is quiet and smooth when releasing it.
My FED collection grows and grows ... ;-)
Reply author: AidasCams
Replied on: 20090715012524
The latest serial number of Fed type-d I know is #172788. The very late type-d cameras (Jacques have mentioned about few of them) should be considered as Berdsk cameras already. Although bearing NKVD markings yet, they were assembled in Siberia indeed ...
Best Regards,
Replied on: 20090715163041
Hello Aidas!
Of course OK to decide that those last 1d should be in fact "1d Berdsk" if they were made or assembled in Berdsk.
But we had already discussed of an 1e (Berdsk??) type S with a passport printed in Kharkov and signed in august 1941, serial number 180xxx. So we had thought that all the cameras before this number were made in Kharkov too...
Of course, nothing sure about this period, unless there is something new, for example in Viktor Suglob's book?
Congratulations for the growing of your Fed 1 collection, Ulrich! Mine too! [:D]
