What do you use to clean your cameras?
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=1420
Printed on: 11/11/2026 3:24:06 PM
Topic author: Gelios
Posted on: 20091106181526
everything is in the title...
I got some cameras which need to be cleaned (FED & Zorki 1). I would like to find a efficient but non abrasive solution.
Any idea?
Thanks! [;)]
Replied on: 20091106193945
Lighter fluid and toothbrush, method courtesy of Ulrich Witte. Works the best! For leather I use those preoiled shoe shine sponges, but it's better if it's not completely new so it's not very oily anymore.
Replied on: 20091107020804
As Vlad wrote I use a tooth brush and lighter fluid to get rid of the dirt in the grooves of the winding and rewinding knobs. They are like new after that. It's also a good way to clean the gears of the winding and shutter mechanism. The camera looks perfect if you also clean the slit of the chromed screws with the toothbrush :-)
For the chromed parts I use NevrDull, rub them with only a little pressure and clean them dry with a piece of cotton or something like this (old t-shirts work best).
Reply author: mermoz37
Replied on: 20091107043555
I agree...
but add :
for dirty grooves on buttons ,At first, use a needle or a point to unstick the grime and then do as Ulrich wrote.
To limit the attacks on the chrome-plated surfaces, I use an eraser containing metallic grains as we can found in "do it yourself" shop (sometime used to ease wounds on leather clothes)
Reply author: Poolhall
Replied on: 20091107055605
Nail polish remover can be useful, but you need to be careful as it can lift paint, even WD40 and cotton buds can often clean things well as its mostly white spirit afaik, but definitely agree on the lighter fuel[:)]
Replied on: 20091107064731
yes richard , I use it sometime too.
So,if I can dismantle some parts , I use an Ultrasonic whashing machine (see "CONRAD" Shop or so) usually used for glasses or jewelry cleaning.
Reply author: Gelios
Replied on: 20091107080533
Thanks guys for your comments![8D]
To be precise, I an looking for solutions for chrome-plated surfaces. For internal cleaning, I use mostly alcohol, toothpick and cotton swabs.
Replied on: 20091107082434
I use brasso for chrome but be very careful it's abrasive
Replied on: 20091107094921
I use Dremel (that small drill like thing) and car chrome polish.
Replied on: 20091107170945
Alain, right, to use a needle or something like that to remove the hardened dirt saves a lot of time for the toothbrush. I also have tried to use an ultrasonic cleaner but it does not work as I expected, it's good for my glasses but it does not remove all of the dirt on the knobs. The toothbrush method with lighter fluid is much faster.
Nicolas, as written before, NevrDull works very good for me. You can get it in a motor bike store, the bikers use it to polish the chrome on their machines. A box with about 200g of it costs here 5 or 6 Euros and lasts really long. You only need very little amount of it.
But don't rub too hard, as I remenber Bill says it could be abrasive to the chrome on Contax/Kievs but I haven't had any bad experience on my FEDs and Zorkis until now. Their chrome seems to be harder and thicker.
Replied on: 20091108073226
" Fed/Zorki chrome seems to be harder and thicker."
yes indeed ! I often used a copper/brass brush screwed on my drill machine whithout problems (especially on button grooves).
As said Ulrich , sometimes Ultrasonic is not so fast as brushes.
Replied on: 20091108080816
As for me, lighter fluid and toothbrush, thanks to Ulrich.
For the old grease inside, cotton and light naphta (essence C in France). If necessary, WD 40 for the screws of the lens. Much less than for the winches of my boat!! [:D]
Reply author: okynek
Replied on: 20091108110249
My 2 cents is that I found that mix of lighter fluid and alcohol work slightly better then lighter fluid along.
