elikon 2 different serial number
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=1849
Printed on: 11/22/2026 6:50:56 PM
Topic author: naaimad
Posted on: 20110807141926
hello, i've recently bought a elikon 2 , but it's serial number is 9601014. in wiki catalog http://www.ussrphoto.com/Wiki/default.asp?WikiCatID=74&ParentID=1&ContentID=922&Item=Elikon+2 there aren't this kind of serial number. can anyone enlighten me? :)
but my biggest request is: can anybody help me with an instruction manual?
thank you in advance.
Replied on: 20110807202013
I think regarding serial #, they are inside the camera in the film chamber, often on a paper sticker if I'm not mistaken. I don't have this particular Elikon, but other models are like that.
Reply author: RCCCUK
Replied on: 20110808021507
You are quite right, the serial number on your Elikon-2 does appear to be strange. The first two digits of some Elikon cameras indicate the year of manufacture. The Elikon-2, as far as I am aware was only manufactured in 1990 and 1991, hence the serial numbers listed in the Wiki Catalog. Is the serial number on a paper label? If it is, it may have been changed at some time.
David.
Reply author: naaimad
Replied on: 20110808041909
the serial number is engraved on the bottom plate, as it can be seen in the following picture:
https://lh6.googleusercontent.com/-Ht4JNcrZCKs/Tj-faUmRXlI/AAAAAAAABr4/9-J4_UgweTw/s800/IMG_20110808_112125.jpg
another difference is that the shutter button is pink, not red:
https://lh3.googleusercontent.com/-ZiuYVW6Wml8/Tj-fc-_IPzI/AAAAAAAABsk/APWfMRwUueg/s800/IMG_20110808_112100.jpg
until i'll find a instruction manual (scanned, in russian, it doesn't matter) can anyone tell me what kind of batteries does it use?
thank you.
Replied on: 20110808093210
Very odd serial number, five years gap to all previously known examples!
Batteries: with most USSR cameras you use either A76=R44=G13 or larger PX625 type. And alkaline or silver 1,5 volt is good even for the older ones like Zenit. In this Elikon you can use both: there should be a plastic "adapter tube" if you use two smaller A76=R44=G13 batteries. If tube is missing or you have only PX625 at home the usen two of those. Simple!
Replied on: 20110808151856
thank you cedricfan. those are precious informations. [:)]
