etude slide projector lamp changing
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2052
Printed on: 11/10/2026 11:02:01 AM
Topic author: davidcristina
Posted on: 20120505152857
i have an Etude slide projector from my aunt.
I plugged it and unfortunately the lamp burned out. Fortunately i have the second one, but i have no idea how i replace the burned one with the new one. what is the procedure? I don't have the manual :(
Can anybody help me?
Thank you a lot.
Cristina D.
Reply author: mistereef
Replied on: 20121126030824
unscrew two screws at black base of where bulb is attached to, it's same piece that has power conector. then you can remove bulb and/or connect this piece to power to make sure bulb works fine before screwing it back on again.
