Menton with Fed and Sonnar
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2200
Printed on: 11/4/2026 12:17:40 PM
Topic author: Jacques M.
Posted on: 20121027115331
Some days on the French Riviera, at Menton, not far from Nice.
I tried two arrangements.
First, my 1941 Fed S with the Jupiter Sonnar (1946 Zeiss barrel, 1974 KMZ serial number, front part probably changed), a picture of the village.
http://www.ussrphoto.com/UserContent/27102012_CCI27102012_00003.bmp
Then, always the same Fed S, but with a 2/5cm wartime Sonnar (M marked):
http://www.ussrphoto.com/UserContent/27102012_CCI27102012_00004.bmp
http://www.ussrphoto.com/UserContent/27102012_CCI27102012_00005.bmp
I had much pleasure to use this russo german material... so that my Canon EOS3 stayed in its bag!
Reply author: Fred_L
Replied on: 20121028125323
It's impressive....[8D]
Did you use some filters?
Replied on: 20121029044836
Hi Fred!
Just a skylight filter, to protect the lens.
But looking closely at my pictures, I wonder if the shutters work perfectly: on the first pic, there is an underexposed zone on the right. A small piece of film or a matter of regulation? Surely, I will have to see that.
About my 2/5cm collapsible Zeiss lens (the two last pictures), I discovered something funny. The serial number is 2711193 on the front, but when dismounting, a 2936760 is engraved on the barrel. Probably all that was taken from Germany to Russia as spare parts, then remounted and regulated for Feds...
Here is a picture of this Sonnar (with the Fed S I used).
http://www.ussrphoto.com/UserContent/29102012_meter scale 003.jpg
