Start SLR camera - lenses
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2292
Printed on: 11/10/2026 3:38:44 PM
Topic author: Fredstarter
Posted on: 20130214090556
Dear friends of USSR built camera! I apologize for the following crazy idea: The START SLR camera (I just have bought one, it's on the way to me) has only one lens specially designed for it, the Helios 44 with automatic diaphragm. Would it be possible to take, let us say, a MIR 1 wide angle and to modify it the same way, i.e. making a base with automatic diaphragm for it? I think this would be an easy task for the many gifted technicians in the countries of the former USSR. Or am I too naive? Thanks for your answers and all the best to you all: Your new member Fredstarter
Replied on: 20130214092615
Yes, if you want a macro lens, or you have a thick wallet.
There already is an adapter for use of M39-lenses, but with manual aperture. There simply is no room to make a mechanism from outside of lens into inside of mount. Unless you do the adapter thick enough, which makes the lens to macro.
Putting the system onto an existing lens would mean a lot of work when done afterwards. Most likely you would also need one extra Start lens for parts. And this work to every single lens, not as an adapter to be used on several lenses.
Replied on: 20130222052633
An wonderful adaptation made in an Helios 44 M~7 was made mantaining automatic functions and correctly operating in astart camera I saw recently. I will sonn post the pictures.
