Rodina
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2440
Printed on: 11/13/2026 12:22:37 AM
Topic author: Luiz Paracampo
Posted on: 20130823185109
See at camera Articles.
the text I tried to include but was impossible
Hybrid camera developed by KMZ group of young designers under the direction of Marentsov (developers - N. M. Marenkov and S. M. Tikhomirov) around 1952. It was a combination of Zork, Kiev and Exakta with Contax bayonet mount. Introduced the combined view-finder with large base range finder,together diopter ajustment. Double dials of speed selections: 1-1/25 and 1/50 - 1/2000; two synchronizing posts and automatic release, removable back cover. "Jupiter-8" lens. Only a small number of prototypes were made.
Regards LP
Replied on: 20130824120607
http://www.ussrphoto.com/Wiki/default.asp?WikiCatID=50&ParentID=49&ContentID=1585&Item=Rodina+the+land+mark+to+hi%2Dtech
Replied on: 20130830081129
A very interesting camera, alas never produced.
The Princelle says that the Zorki 3 was preferred: less expensive to make...
Thanks, Luiz, for the rear part of that camera![;)]
Replied on: 20130830194528
Hello Jacques
Did you see the PDF?
Replied on: 20130902073118
No, I had not.
The comparison with other contemporaneous cameras is exciting.
If we go farther, I should add the Nikon S which has a Contax bayonet mount and a Leica type shutter. Exactly like the TSVVS.
Thanks for that, Luiz!
Replied on: 20130902100225
Thanks Luiz for this detailed technical analysis! Very interesting to see how your tie different models together. It's very interesting that KMZ had tried numerous times to introduce contax-type mount into their cameras and every time the cheaper (M39) solution was picked over it. So in the end Arsenal was the only factory monopolizing the "technology" if we're not considering the unknown origin of the TSVVS cameras.. to tell you the truth I think maybe this unknown camera you call TSVVS-2 is more of a Leningrad-2, a logical progression of that particular line [:)].
