pocket on the rear of fed zorki etc cases... why ?
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2731
Printed on: 10/22/2026 6:39:06 AM
Topic author: stephanvdz
Posted on: 20141206075812
we all know those pockets with white cards, or fixed metal plates ... on the back part of fed and zorki cases.
why this ? on very early case, the plate is metal with linen and fixed... on later is a plain white plate made of some kind of plastic...
does anyone know what is the use of this plate ... ?
Stephan
Reply author: Lenny
Replied on: 20141206081627
This topic was discussed in the past, you will find the thread with a little search.
Some said it's a protection for the camera-body when pressing the case-buttons, early bodies were not so strong and even on later Zorki-C you can find marks of the case-buttons on the vulcanite or the green and white cover.
Some said it's something to take notes, and often you can find notes on that plastic card.
I think it's a kind of protection.
Replied on: 20141206085153
I thought it was an aid to load film into bottom loader
Reply author: Lenny
Replied on: 20141206090707
<br />I thought it was an aid to load film into bottom loader
Yes, that is a possibility too and was discussed also.
But Stephan said that first they were made of metal with linen and fixed. I didn't know this, so the original purpose might be protection, then it was changed to a moveable plate to help loading the film and owners also used it to take notes.
