Zinc pest
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2830
Printed on: 11/7/2026 3:58:58 PM
Topic author: uwittehh
Posted on: 20150501032403
I have heard of this before but I have never seen what damage it can do. Here you can the it on a rangefinder of a Leningrad. The camera does not work, so I opened it. To get to the shutter you have to remove the rangefinder. It comes in parts off and cracks in my hands :-(
http://ritzelkiste.de/ussrphoto/zp01.jpg
http://ritzelkiste.de/ussrphoto/zp02.jpg
Reply author: jed
Replied on: 20150501034559
Quite impressive ! Maybe Cyanoacrylate glue in between cracks will help ?
Replied on: 20150501080604
Jed, I don't think that this will help. The entire structure of the Zinc is broken if there is Zinc pest in it. It is the result of bad or with dirt contaminated alloying and is not stoppable.
Replied on: 20150501081243
I think too.
I had an early Foca, a French camera made in zamac (zinc, aluminium, manganese and copper). Many parts of this camera were gradually desintegrated into a white powder. Heart breaking.
Replied on: 20150501093519
Ulrich, I've never heard of this before, can you expand on what causes this exactly?
Reply author: xya
Replied on: 20150501112739
see http://en.wikipedia.org/wiki/Zinc_pest if needed, you can switch over to french and german from the article directly.
Replied on: 20150501113725
Thank you! Learned something new today!
Reply author: Fotohuis
Replied on: 20150501123408
If you have this, nothing can be done because it is inside the metal itself. Even some Leica models can have it so it is not a F.S.U. camera problem only.
Robert
Replied on: 20150501154606
<b>Ok with a enormous patience we can restore this Leningrad Rangefinder.
Your cradle is still in good condition I picked some worse than this.
I did this kind of restoration in some cameras
First we can restore all structure by emerging the whole metal unit and metal parts in a solution of Carbon tetracloride and Methyl Cyanocrilate glue.- suficient to obtain a complete penetrating fluid
This penetrates the Zamak mass and stops oxidation carefully reglues all parts in order to recompose the structure
the important point is recompose the bottom plane scratching in a sand paper over a plane glass further remount glass parts again.
I am just preparing a complete explanation of the Leningrad rangefinder working which is essential for the recalibration and correct working. As soon it will be ready I will post it.
</b>
Replied on: 20150501154741
Jed came near the solution!
Reply author: levonsa
Replied on: 20150501173929
Ulrich Hello!
No need to reinvent the wheel!
About this rangefinder is better to forget all!
Write me an email. I'll give you another normal rangefinder camera Leningrad.
Replied on: 20150507143959
Levonsa, thanks, but there is no need that you send me a rangefinder. I had two broken Leningrads and made one working of them :-)
