something wrong
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2940
Printed on: 11/10/2026 9:22:06 PM
Topic author: Luiz Paracampo
Posted on: 20151210195711
I cannot post the image of a 6x12 Horizont nor any other else.
Text:
Horizon 6x12cm Prototype
Prototype camera for panoramic photography made by KMZ, Moscow. The camera is a research model for roll film 120, using parts of the 24x58mm Horizon. The camera is big and heavy (160 x 112 x 80/120 mm, 1.320 grs), its brown anodized body structure was turned from solid aluminium, the wing-like back doors are aluminium sheet metal and chrome plated brass. Negative format is 55x130mm. Single speed shutter. Fixed focus Contessa-Nettel Doppel-Anastigmat Teronar 5.4/7.5cm no.396880, the diaphragm is adjusted by turning the inner ring of the rotating dial next to the finder. The detachable finder with built-in level is a modified series model from the original Horizon, with a taller finder base and a sliding shoe added to it. Film transport and shutter tensioning by turning the wheel next to the release, watching the numbers behind the red window in the camera back (no frame counter). The mechanism of the rotating drum runs, but is a little sticky. The camera is a well made prototype that must have been made well before the later 6x13 model 205PC.
See Page http://www.westlicht-auction.com/index.php?id=4
Reply author: Zoom
Replied on: 20151211035456
<br />something wrong...
Indeed, this self-made camera has no bearing to KMZ.
