FED puzzle
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=3154
Printed on: 11/6/2026 11:36:44 AM
Topic author: Alfa2
Posted on: 20170205111308
Recently I have bought this FED in condition which can be seen at first photo.
It's a pitty this beautiful camera is in parts. So I'd like to assemble it. I can see there are no screws and there are no one of two small lamellas which are behind pressure plate. This small lamella is not a problem but screws are a small problem.
So now I have few questions:
1) Do you think I have all parts needed to assemble the camera ?
2) Is this vulcanite adequate for this serial number of camera ?
3) Where can I find screws which are similar to those which are missed in my camera ?
http://i1238.photobucket.com/albums/ff500/Planistigmat/FED1.jpg
http://i1238.photobucket.com/albums/ff500/Planistigmat/FED2.jpg
http://i1238.photobucket.com/albums/ff500/Planistigmat/FED3.jpg
http://i1238.photobucket.com/albums/ff500/Planistigmat/FED4.jpg
Replied on: 20170205143439
Hi Alfa,
At first sight, you have everything to remount the camera, except one of the springs behind the press film, and all the screws...
I confirm that you have the good vulcanite for the good serial number (a late 1b, always interesting before the 1c-s). The screw which tightens the shutter box to the body is already missing, like on my 51287: 3 numbers before. And you probably have a release button with concentric circles too.
For the screws, perhaps you will find what you look for there: http://www.ebay.fr/sch/nobbysparrow/m.html?ssPageName=STRK%3AMEFSXS%3AMESOI&_trksid=p2053788.m1543.l2654
I must say I have one or two bodies which serve me as "givers" when necessary. But all the screws: it's too big for me.
Good luck. And tell me if you have problems: I have the sister camera!
Reply author: Alfa2
Replied on: 20170206040341
Hi Jacques
Thank you for your help.
The most important that I have everything from this body, I mean everything suit this serial number. So it is worth to remount.
I have screws from Zorki C. They fit but they are little bit different - too glossy, as I remember.
Reply author: SteveA
Replied on: 20170206102240
Hi, if your Zorki C is a bottom loader you may be able to use the springs from behind the pressure plate to fit to the FED.
Reply author: Alfa2
Replied on: 20170207073450
Thanks SteveA, I know. [:)]
That is the reason why I have written spring was not a problem.
Replied on: 20170207160654
Just a detail, Alfa: you have the tiny screw inside the speed dial, and it is in a good condition?
A problem not easy to solve...
Reply author: Alfa2
Replied on: 20170207162616
There is no the screw at all in my FED. I will try to take it from Zorki C.
