Fed macro on A7.
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=3203
Printed on: 11/4/2026 12:17:36 PM
Topic author: Jacques M.
Posted on: 20170707073335
A photo made with my prewar macro Fed. Not easy: sure this lens was not a daily one...
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/772017_DSC00222.JPG
http://www.ussrphoto.com/UserContent/772017_DSC00222.JPG
Of course, the result is soft. But at minimum distance, it's difficult to focus correctly. Other photos to come, when there is less wind here.
Replied on: 20170708152035
Another one, better, I think.
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/872017_DSC00228.JPG
http://www.ussrphoto.com/UserContent/872017_DSC00228.JPG
Not so bad. But I really wonder how it was possible to use such a lens in the thirties, without rangefinder, of course, and with a very limited depth of field...
Reply author: Alfa2
Replied on: 20170709152512
Good question. I never thought about that. I'm used to all those Leica macro equipment and I never thought there is no equivalent in FED equipment.
Replied on: 20180108081527
Always with a Fed macro "rigid":
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/812018_DSC00328.JPG
http://www.ussrphoto.com/UserContent/812018_DSC00328.JPG
Reply author: Alfa2
Replied on: 20180108162915
I love cats. I grew up with cats.
A very nice photo and a very nice cat. And horrible lens. [;)]
Replied on: 20180109051723
Not so horrible, in fact, even if sharpness is not its main quality. But when using the magnifying on the nose, it's not so bad... Anyway, my other Fed macro lens is worse!
Reply author: Alfa2
Replied on: 20180114095010
Here sharpness is OK. But contrast is poor.
Reply author: seany65
Replied on: 20180115174329
That cat looks like it's thinking "Another inch closer with that thing and I'll rip your head off!"
Replied on: 20180118095559
<blockquote id="quote"><font size="1" face="MS Trebuchet, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by seany65</i>
<br />That cat looks like it's thinking "Another inch closer with that thing and I'll rip your head off!"
Ha, ha!
Replied on: 20180118112538
<br />Here sharpness is OK. But contrast is poor.
I think you are a bit severe with our old things, Alfa.
Of course, contrast is poor. But my cat itself is not very contrasted (!) and the light was low. When I have time, I will take some photos with a prewar Elmar on a NOOKY to compare.
Reply author: Alfa2
Replied on: 20180118142957
Jacques, you're right on one hand but on the other hand - just please lok below.
Now I don't have any cat but I can show you a photo made with non coated Elmar 5cm f/3.5 in 2016. I mounted it on NEX 5N.
Contrast seems to be better.
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/1812018_karnity.jpg
http://www.ussrphoto.com/UserContent/1812018_karnity.jpg
Replied on: 20180208085146
It's of course not possible to compare photos made in different conditions.
That said, you are right, alfa. I made some photos with a prewar Elmar and an appropriate ring of 5 cm. No doubt: the contrast is much better.
So, as I never desert, I have bought another macro Fed lens. That time, photos are much better. The cat you have already seen, but with the "new" macro Fed:
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/822018_DSC00375.JPG
http://www.ussrphoto.com/UserContent/822018_DSC00375.JPG
Replied on: 20180208090100
My wife's stuff (focus on the paper, in the middle):
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/822018_DSC00371.JPG
http://www.ussrphoto.com/UserContent/822018_DSC00371.JPG
The lens is really very clear, without that common "milky" haze. I'll have to try it outside.
Replied on: 20180208152723
And a last one with a small part of my own stuff:
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/822018_DSC00372.JPG
http://www.ussrphoto.com/UserContent/822018_DSC00372.JPG
With a A7, it's possible to avoid the image of the diaphragm, when the light is too straight. I think that this macro Fed could be a very good common lens on a numerics. The second life for that lens which certainly never knew its first one?
Reply author: Alfa2
Replied on: 20180209124018
Thank you for nice photos. [:)]
Now I'm a little bit surprised.
Your "new" macro FED lens is really good.
I have tested on digital cameras and on film a few standard Industar 10 lenses made for FED NKVD. Sharpness was very starnge. Photos seemed to be sharp and not sharp simultaneously. Contrast was good at some of lenses while it was pour at other of them.
But here your lens is sharp and contrasted.
Congratulationen Jacques.
Replied on: 20180210153042
Thanks, Alfa.
No doubt the lens was cleaned: there are some light traces of demontage.
But I had not expected such results which are better than my prewar Elmar's. For me, these early Fed lenses were only for collection...
Replied on: 20180211080044
The same macro lens for an outdoor photo. The sun is poor, here...
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/1122018_DSC00383.JPG
http://www.ussrphoto.com/UserContent/1122018_DSC00383.JPG
No real difference with those taken by my prewar 3,5/50mm Fed lenses.
Reply author: Alfa2
Replied on: 20180211145326
Yes, it's good lens.
Jacques, do you have any photos taken with prewar 3,5/50mm Fed lenses ?
Could you share some of them ?
Replied on: 20180214035449
As soon as I can, Alfa. In a separate thread, so that we can compare the results of different 3,5/50mm lenses.[:)]
Reply author: Alfa2
Replied on: 20180214045106
Great.
I thought about the same thing, I mean to create separate thread to compare the results of different 3,5/50mm lenses.
