Fed vs Zorki
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=325
Printed on: 11/11/2026 1:58:58 AM
Topic author: ray j gun
Posted on: 20080104130657
Is there a quality difference between the Fed and Zorki brands? I am interested in an early version of the cameras.[:)] I presently use a mint Leica IIIc and would like to reduce the wear on that rig.
Thanks!!!
Ray
Reply author: okynek
Replied on: 20080104145805
I believe this is only matter of personal preferences.
I really like early FEDs. I believe they are made better then cameras after WWII.
And more.... Just to think that camera you holding in you hands made 70 years ago by others small hands of orphans, which parents was killed during revolution, which was saved by Communist government, which later raze up to protect this government against Hitler occupation, and which more likely was killed during WWII or after it, by Stalin purges .... this cameras are more then a collector's peas... they have to be keapt in golden boxes.
Replied on: 20080104170644
For a good workhorse with results comparable to Leica, I would probably recommend a FED-2d or FED-2L.
Not sure if it's early enough for you, these are from 50-60s
Reply author: nightphoto
Replied on: 20080104200731
I like the FED-1 better, also because of the history, but Zorki-1 is good too, and both feel like a Leica and give good results.
I think, especially if you want to use your Leitz lenses on a FED body, that it might be best to buy one that is made just after WW II. This is because the lens thread for after the war FEDs will match the Leica thread, but the pre-war FED has a slightly different thread (M39, but a slightly different distance between threads).
An early Zorki will fit your Leitz lenses fine since they are all made post-war.
With either FED or Zorki, it would be a good idea the have the camera cleaned, lubricated, and adjusted, which will make it feel smoother and more like a Leica.
Reply author: fedka
Replied on: 20080104215321
For a user I always prefer and recommend a Zorki (we are talking about original FED and Zorki, i.e. FED 1 and Zorki 1).
I always believed that KMZ was generally a better factory than FED. And lens compatibility is alwasy better with the Zorki.
FED has historic value, especially prewar models. But there are problems using newer lenses on prewar and early postwar FEDs. FED shutters (postwar) are louder and clunkier than Zorki's.
Reply author: ray j gun
Replied on: 20080104232646
Thank you all for your responses!! Excellent information. This an excellent resource and I hope to contribute in the future.
R
Replied on: 20080105014042
Neither FED nor Zorki. The correct choice is Leningrad. Suberb finder, great looks, and the lovely winder!
http://www.cedricfan.sivut.ws/Juhani's%20website%20ORIGINAALIT/
Reply author: fedka
Replied on: 20080105084622
Leningrad is surely the fanciest Soviet made camera. I had several, still have two, bought them, sold them... never shot anything. I never felt in control of this camera.
Replied on: 20080105182107
See now, ray j gun, it all only matter or preferences [:)]. Some preferred FED some Zorki, some other cameras. The matter of the fact is: if camera working after 50 years in uses, then it must be a good camera. You can not make a bad choice. Just make sure that you buying from reputable seller. Too many junk cameras selling on eBay. Really easy to burn on. Ask questions before you buy. And try KIEVs you will not be disappointed.
