panoramic head FED
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=3325
Printed on: 11/7/2026 3:42:50 PM
Topic author: levonsa
Posted on: 20180607191959
All greetings!
Recently there was such an interesting FED tripod with a panoramic head.
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/762018_IMG_7685.JPG
http://www.ussrphoto.com/UserContent/762018_IMG_7685.JPG
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/762018_IMG_7693.JPG
http://www.ussrphoto.com/UserContent/762018_IMG_7693.JPG
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/762018_IMG_7773.JPG
http://www.ussrphoto.com/UserContent/762018_IMG_7773.JPG
Reply author: Alfa2
Replied on: 20180609031332
I have a question. When those tripods and heads were made ?
Reply author: levonsa
Replied on: 20180609170205
If you look at the logo, it's post-war.
Reply author: Alfa2
Replied on: 20180609171613
Yes, logo on panoramic tripod is postwar.
But logo on tripod is the same like logo on some lens caps on FED NKVD.
Replied on: 20180609171930
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/962018_IMG_7766.JPG
http://www.ussrphoto.com/UserContent/962018_IMG_7766.JPG
Reply author: fedka
Replied on: 20180609184345
The clamp itself might be prewar, and the head with a new logo is postwar, so perhaps the head was a separate accessory that was added to the clamp later.
Replied on: 20180613173345
Yuri you are wrong. In pre-war supports, the inscription of the FED differs from the postwar ones. It is slightly smaller in size.
Yuri, if you look closely at the casting of a tripod with a panoramic head, you will see that it does not look like a serial tripod. To make it more clear, you need to take an ordinary tripod, unscrew the head and compare the ending.
They have nothing in common! So we will look for information further.
Replied on: 20180614092942
observe also the head is mounted upside down!
Replied on: 20180614141714
Luiz!
The head is wound on both sides.
Replied on: 20180614142508
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/1462018_22.JPG
http://www.ussrphoto.com/UserContent/1462018_22.JPG
Replied on: 20180615120841
<b>The ball head is upside down
</b>LP
