Can't set shutter speed past 250
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=3556
Printed on: 10/1/2026 6:08:41 PM
Topic author: mrjoshida
Posted on: 20220411052221
I recently got a Revue labelled Fed 4 that seems to be working smoothly aside from one strange problem. When I change the shutter speed from 250 and then take a shot I can't return to 500, the shutter speed dial will only let me select from 250 down to 1. If I take a shot on 1 the shutter fires quickly and then I can rotate the dial all the way around and back to 500. Has anyone seen this kind of behavior before?
Reply author: Fred_L
Replied on: 20220412024630
Hello
Is shutter remains open when you are using B setting?
Reply author: SteveA
Replied on: 20220415070819
Hi, its possible the shutter speed knob has been replaced incorrectly. Wind the shutter and make sure that the index mark on the speed knob rotates clockwise as far as 1/30th. If it won't, then try to rotate it anti-clockwise past 1 second. Do not force it. Should this be the case then you need to loosen the grub screw and reset the position of the index marker against 1 second, then check it will now move back to indicate 1/30th.
However if there is no issue with the shutter speed knob then it sounds like something is wrong under the top cover with the speed selection mechanism
