New curtains source for zorki
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=3726
Printed on: 10/1/2026 2:02:53 PM
Topic author: cainiao_2020
Posted on: 20260630123822
i recently bought some etone shutter curtain to replace the old ones in my zorki3.
I noticed because the etone curtains are only 0.15mm at speed 1/1000 the curtain dosent create a gap, i had to make the drum thicker by adding extra curtain material.
now the gap for 1/1000 at the begin of the travel is about ~1,2mm and at the end ~3,4mm.
So im looking for a better source for zorki curtains since the last post discussing is already over a decade old.
Replied on: 20260630141048
I buy my shutter clothes at nobbysparrow on ebay, he has clothes that are 0.2mm. And instead of making the drum thicker you can change the position of the curtain on the big drum. Only 1mm makes a big difference.
Reply author: cainiao_2020
Replied on: 20260630170038
thanks, moving the curtain 1mm unfortunately dosen't work on 0,15mm curtains because the shutter wouldn't fully close while cocking the shutter.
didn't knew 0.05mm in thickness would make such a huge difference at 1/1000 because the etone curtains seems to work ok for 1/500.
i will look into the curtains from nobbysparrow for my next CLA
Replied on: 20260711163149
I'm familiar with the problem of the curtain not closing properly when cocking. I've always been able to solve the problem by adjusting its position on the large drum.
I haven't had any problems with nobbysparrow's curtains so far. I also sell refurbished cameras and have only received positive feedback until now.
Maybe the slight difference in thickness does make a difference.
Good luck :-)
