ZENIT-E
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=644
Printed on: 11/11/2026 12:01:23 PM
Topic author: mattyde
Posted on: 20080521034818
Hello i brought a new zenit-e camra boxed with manual...and i have no idea how to use even after reading manual!
when i load the camera and turn the shutter and hit the boten the mirror flips up and the shutter opens but i dont know if its taken the picture?
Basicly!! how do i take the picture!
Reply author: dgillette4
Replied on: 20080521092840
The Zenit E works like most cameras. You bring the film across into the takeup reel, advance a couple of frames close back .Then I take up a little of the slack in the rewind , but just enough to slightly tighten the roll. Then I advance a frame and look for the rewind to turn opposite the arrow direction, If so it's loaded correctly. (But before this loading procedure) you can open the back look at the curtain and watch the curtain move across the opening, Then release the shutter while watching and you should see light through the lense. Slower shutter speeds are easier to see. If all above is happening your'e in business. Remember to advance lever before changing shutter speed (very important). After you shoot all frames You rewind by pushing and holding button Next to frame counter, At the same time turn Rewind knob in the direction of the arrow. Notice that the center part will rise to make it easier to grasp..Once you feel all drag on the rewind iknob is easier, you an open door by latch on lleft side and then raise rewind knob to remove exposed film. Let me know if there are any other specific questions you have. Don
ZORKIE'S Survive
Replied on: 20080521103944
Great explanation Don! One common mistake is I guess that I made at least when I first saw the Zenit E is that the shutter release button is on top of the frame counter/wind dial and NOT the one next to it. The one next to the frame counter is a rewind release as Don pointed out, even though it makes the shutter sounds [:)]..
Reply author: okynek
Replied on: 20080521191541
And not to forget to close apperture before you shoot and open it to focus.
I always seems to have problems with it [:)]
Replied on: 20080521193815
I have been there and done that...he he [:D] Don
ZORKIE'S Survive
