salyut C... erratic shutter
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=977
Printed on: 10/22/2026 4:50:46 PM
Topic author: stephanvdz
Posted on: 20081201132229
hello all, My salyut C is behaving badly. The shutter is erratic, sometimes it goes into slower speeds sometimes not... so it has to go to the technician, but my tehcnician doesn't know how to open that thing. (He's usually competent and works on hasselblads and other complicated tools, former nikon F3 technician) Where could I find a good technical manual ? preferably in french or english ?
The other way would be to buy a new body... Kiev88 something...but I want a working one...
Stephan
Stephan
Reply author: nathandayton
Replied on: 20081201142610
Unfortunately, a good technical manual does not exist in Russian but it leaves a lot to be desired!
Here are a couple of links:
http://kievaholic.com/tentok88.html
http://www.commiecameras.com/sov/mediumformatcameras/singlelensreflexcameras/cameras/manuals.htm
On the bottom of the page is the repair manual in Russian.
I have had one of mine rebuilt http://www.araxfoto.com/
and cannot be more pleased, It is immensely smoother and more convenient to use.
Replied on: 20081201175523
Stephan
Try to remove the lens and drop some cigarrete lighter fluid (those intended for Zippo and similar) at the bottom base where lays the camera mechnics. frequently this does some miracles!
Reply author: dgillette4
Replied on: 20081201201023
As Luiz states the lighter fluid under the bottom baffle near the front might work, The timer mechanism is located there. I once repaired a 1000f Hasselblad this way and the timer is also in the front bottom. If not get a hold of Trescam camera repair. He repaired a Kiev88 of mine that was a stretcher case, I bought it by mail and it was a mess. Works perfectly now. I highly recomed him . I use three KIiev 88s, and there is variation between them all especially the fitting of the backs. Don[:)]
ZORKIE'S Survive
Replied on: 20081201201339
I almost forgot there is a site called I-offer and the seller is named (manuals to go)...He has Kiev88 books. Don[:D] Das vee danya
ZORKIE'S Survive
Reply author: stephanvdz
Replied on: 20081222153715
tried the lighter fluid trick... got the 1/15 and 1/8 working again... but I think the trip back to kiev will be necessary... Arax seems ok... but if you have any other adress, I'm quite interested
Stephan
what to buy instead ? I've some B lenses... but also some old exakta plus P6 lenses (180/2,8 and 300/3,5)... so may be I'll buy a CM body with 3 adapters ? does it sound logical ?
wich are better Arax or hartblei ?
Stephan
