 Help! - Zenit 5
Vlad Posted - Sep 22 2007 : 9:54:34 PM
Had anyone ever used Zenit 5 motor? I took mine apart, took off a bottom plate, and guess what? No batteries just empty sockets.. am I completely screwed?
13   L A T E S T    R E P L I E S    (Newest First)
Vlad Posted - Sep 25 2007 : 4:00:14 PM
All right, I'll give that a shot! Thanks!
Luiz Paracampo Posted - Sep 25 2007 : 3:58:51 PM
That way I suggest the external power supply via extension flash cord.
Those Ni-cad batteries were originally uses in German hand flashes such as Metz and Braun The demise of production of such types led to a short market supply.
Vlad Posted - Sep 25 2007 : 3:41:19 PM
Thanks Luiz!
I had opened the camera and have seen these sockets. But before I go to these extremes that you have described, there may 1.35V batteries here that may fit, maybe not snuggly but enough to power the camera... I really don't want to modify it this way it since it will destroy the historical value of this beautiful unit, as these are not very common.. I will search around this weekend in Radioshack stores here that sell batteries, maybe I will find something.
Thanks!
Luiz Paracampo Posted - Sep 25 2007 : 3:34:57 PM
Vlad be not desperate! In the bottom of the Zenit 5, there are a chrome cover. There you see the traditional tripod screw, an on-and-off knob for the batteries and a small socket for battery recharge.
This socket is a 3mm standard PC extension used for flash connection.
The original flat Ni-Cd batteries are nowadays difficult to obtain. My camera came with original "C" "Svetlana" batteries.
Suggestion: You can use standard rechargeable telephone cells, that are stronger than original ones (that is has more amperes per square inch- The voltage is the same). You may use four cells connecting two sets of double batteries of the small type and externally use them in series and connecting to the camera through the extension synchro flash cable. This is the first suggestion.
Second suggestion:
If you open the camera bottom you will find a plastic chassis used to carry the four original flat batteries.
Remove it- You will loose the original off-on switch.
Now, without the black plastic chassis, you have an ample space to put in the camera internal those small telephone batteries - Solder the two blocks- You will have four elements. In electronics warehouses you can find a small switch to be screwed in the metal bottom cover. Solder the wires correctly. You have now the camera ready for operation. You can also use the original recharging device coming with the camera. The real operating voltage is 4x 1.35V= 5.40V - No matter you use 6V for driving the camera.
Vlad Posted - Sep 25 2007 : 12:28:22 PM
Yea but that's no fun! :) The emergency wind crank it very hard to turn manually... well maybe... :)
AidasCams Posted - Sep 25 2007 : 12:23:41 PM
Vlad,
You always have an alternative way to use this pretty camera, while it also works fine in manual mode
Good luck,
Vlad Posted - Sep 25 2007 : 11:04:51 AM
Will do as soon as I find these batteries in United States! :) It's quite a challenge. :)
AidasCams Posted - Sep 25 2007 : 11:02:49 AM
You're right, Vlad. I mean Zenit-5 pictures indeed
Vlad Posted - Sep 25 2007 : 09:35:53 AM
You mean of Zenit 5 pictures?
AidasCams Posted - Sep 25 2007 : 06:41:34 AM
We all are waiting your new images in Photo Gallery ...
Vlad Posted - Sep 24 2007 : 11:39:05 AM
Awesome! Thanks! So it does not mention the replacement for the Д-0.26.. I guess I'll have to go around and try to find something that matches that size...
Zoom Posted - Sep 24 2007 : 11:31:03 AM
> anyone know what would be the voltage on the rechargeable batteries used in the Zenit 5?
5 V (4x1.25 V).
See http://www.zenitcamera.com/qa/qa-battery.html
Vlad Posted - Sep 24 2007 : 10:20:30 AM
Ok, another question I guess: anyone know what would be the voltage on the rechargeable batteries used in the Zenit 5? I want to try to find regular batteries that may work with it... I really want to see that motor in action! :)
