 Interesting Early FED-1 Leather Case
nightphoto Posted - Jan 29 2009 : 11:51:59 PM
I have bought this FED-1 leather case, which appears to be fairly early and was described as a case for FED-1S. But as Vlad points out, why would the lens cover section have to be bigger than a normal case, since the F 2.0 lens on a FED-1S is collapsible! Maybe for the 50 mm Macro lens?
It didn't arrive to me yet so I haven't tried any camera-lens combination to fit yet.
Has anyone ever seen this kind of case and know what goes in it?
http://www.ussrphoto.com/UserContent/s-case1.jpg
http://www.ussrphoto.com/UserContent/s-case2.jpg
http://www.ussrphoto.com/UserContent/s-case4.jpg
http://www.ussrphoto.com/UserContent/s-case3.jpg
13   L A T E S T    R E P L I E S    (Newest First)
nightphoto Posted - Jan 31 2009 : 10:50:37 AM
Thank you everyone. I now too believe it is a home modification and maybe the exact size, when I cansee it in person, will help determine the lens it was modified for.
Thanks for the offer of FED S case Jacques, but now that I look, all three of my FED cameras have a case already ... just like the case you have shown for FED S.
fedka Posted - Jan 31 2009 : 09:19:09 AM
I am Yuri
Yes, Bill, this is a home modification. You ca clearly see that the top was removed from this case and an extension was inserted.
Like many other home modifications, it is as good as a factory job. It was common to use a company resources for home needs. After all,
everything belonged to the people.
I've seen many cases reworked in the same way as yours. A real factory job usually has a one-piece nose, like on that FED-Zorki and FED-S.
Yuri
Hi Yuri,
Do you think the leather case I bought is a home modification, maybe to fit a ZK lens or FED Macro lens?
Jacques M. Posted - Jan 31 2009 : 05:52:10 AM
I think too that it's probably a handcraft work to house a big lens.
More probably for a Sonnar if we consider the dates, unless a ZK was put afterwards: LTM Sonnars were made from 1931, if I'm not wrong.
BTW Bill, I have still a spare bag for Fed S (less good than the one in picture). If you are interested...
mermoz37 Posted - Jan 31 2009 : 04:21:34 AM
I am not Yuri,
(sorry Yuri)
but for me , dear Bill it is handcraft work (may be home or small shoemaker atelier).
nightphoto Posted - Jan 30 2009 : 10:44:52 PM
Hi Yuri,
fedka Posted - Jan 30 2009 : 8:46:35 PM
The case on the right on Jacques' pictures is the correct FED-S case. I had 3 FED-S that came in this exact case (still have one).
Yuri
Vlad Posted - Jan 30 2009 : 1:20:43 PM
...or these is a factory camera/lens set that we don't know about
nightphoto Posted - Jan 30 2009 : 1:06:53 PM
OK ... Thanks everyone! Your photos are most helpful.
Looks like it may be a home modification, although the leather looks the same. Maybe I will be able to tell if it was made at home or factory when I get it by looking closely at the stitching threads. It seems to me that I have seen this same type of XXX stitching before on a case, but I can't remember when. I will update when I get the case in the mail.
Jacques M. Posted - Jan 30 2009 : 09:05:17 AM
Hi!
The cases of an S and of a plain NKVD, if it can help.
http://www.ussrphoto.com/UserContent/FS 001.jpg
AidasCams Posted - Jan 30 2009 : 07:21:37 AM
Hi Bill,
I do possess a leather case for Fed-1S camera and it looks a little bit different in comparison with yours ... Unfortunately I can not reach the case at the moment to show you ...
Best Regards,
Jacques M. Posted - Jan 30 2009 : 05:06:31 AM
Hi Bill,
It seems as if an extra piece of leather had been added to house a big lens.
One can think of a rigid or collapsible Sonnar, for example...
Perhaps!
mermoz37 Posted - Jan 30 2009 : 04:16:13 AM
something like that?
http://www.ussrphoto.com/UserContent/IMG_0052.JPG
mermoz37 Posted - Jan 30 2009 : 04:04:42 AM
isn't it adapted for rigide (black or white front plate) or some other Industar ?
anyway the sew (XXXXXX) show an extra nose fitted on normal case.
I have to fish in my batch ,if I remember such a case....
