AlexanderK |
Posted - Jan 09 2010 : 5:50:52 PM Hello, some weeks ago I have complemented my collection with a very interesting and, I think, rare ZK lens with rather low serial number (000532).
 http://www.ussrphoto.com/UserContent/912010_p2.jpg
 http://www.ussrphoto.com/UserContent/912010_p1.jpg
Whether somebody knows, how long this ZK lens has been produced and what is the largest known number? On the I-page http://www.zenitcamera.com/archive/lenses/jupiter-8.html I have found this lens with #1262.
Regards, Alexander |
21 L A T E S T R E P L I E S (Newest First) |
Jacques M. |
Posted - Mar 25 2010 : 10:28:24 AM Hi Aidas,
I think there are some interesting differences between the two 1951 2/50 ZK lenses: yours and David's... Anyway, a genuine 1951 ZK would be a novelty (for me!). But no doubt KMZ could have found some old parts in their boards! It would not be the first time...
I have just checked my datas: all these lenses (the 1950 and 1951 ones) have 7 ciphers, not 6 ?...
AidasCams |
Posted - Mar 25 2010 : 09:58:24 AM Hi Jacques,
let me show you one picture below ...
 http://www.ussrphoto.com/UserContent/2532010_zk-zorki_1951.jpg
Best Regards, Aidas
Jacques M. |
Posted - Mar 24 2010 : 09:30:27 AM Hi David, Certainly you are right, or your lens is an exception. After my datas: - there is no 1951 2/50 ZK lens, - all the 2/50 ZK lenses have "ears" at the diaphragm ring, - last known ZK 2/50: serial number 5005206 (Zhang datas). First known Jupiter 8: serial # 5005386 (my collection, on a 1950 Kiev II), with ears too.
Perhaps it would be useful to put that in the wiki, as the 1950 year is a transition for ZK and Jupiter lenses.
RCCCUK |
Posted - Mar 22 2010 : 08:50:03 AM While have a bit of a sort out of my collection, I have just come across this lens.
 http://www.ussrphoto.com/UserContent/2232010_ZK f2-5a.jpg
 http://www.ussrphoto.com/UserContent/2232010_ZK f2-5b.jpg
Although marked ZK, 1951, No. 011615, it appears to be a Jupiter-8. My guess is that the markings have been added later. What do you think?
David
(http://www.rcccuk.com) |
stephanvdz |
Posted - Jan 21 2010 : 3:47:15 PM you need a spanner wrench to unscrew the back block of the lens... easy... but precise... it's never hardly screwed...
S.
Stephan |
AlexanderK |
Posted - Jan 21 2010 : 2:59:25 PM My lens has the mount as on the right lens. It is not easy to disassemble this lens, so I would try it first on my old Jupiter-8 with the same mount.
Kievuser |
Posted - Jan 20 2010 : 7:30:03 PM quote: Originally posted by stephanvdz
what lens is on the left ? it's the same mount as mine...
Stephan
On the left is a 1955 Jupiter-8. Pleas check #bay item:320467005850 a ZK lens has the same mount as the one on the right.
Zhang |
stephanvdz |
Posted - Jan 20 2010 : 12:16:55 PM what lens is on the left ? it's the same mount as mine...
Stephan |
Kievuser |
Posted - Jan 20 2010 : 12:44:32 AM Hi,
I think ltm ZK and early Jupiter-8's back should have no screws like the one on the right, am I right? Or there are more versions?
Zhang
 http://www.ussrphoto.com/UserContent/2012010_IMG_8941.JPG
stephanvdz |
Posted - Jan 19 2010 : 2:08:55 PM a zeiss number looks like this (here on a 1,5 contax mount sonnar)
 http://www.ussrphoto.com/UserContent/1912010_wartimesonnar.jpg
now you see which black part you have to unscrew...
Stephan |
stephanvdz |
Posted - Jan 19 2010 : 2:03:28 PM ok... you have to take out the back part of the lens... with a spanner wrench (you have two black rings inside the rangefinder cam)... normally it comes out easily...
if you look at the picture of the zeiss lens just above... it's the black rimmed part with two grips for the spanner wrench... nothing hard... on my lenses it comes out easily with the rim only...
Stephan
Stephan |
AlexanderK |
Posted - Jan 19 2010 : 12:46:06 PM Hello Stephan, Hello Jacques,
I have took out the back ring, but I have not found any number . What do I do wrong?
stephanvdz |
Posted - Jan 17 2010 : 3:36:15 PM and a zeiss that should have been a ZK... see the serial number
 http://www.ussrphoto.com/UserContent/1712010_sonnarwartimef2.jpg
 http://www.ussrphoto.com/UserContent/1712010_sonnarwartimef2bis.jpg
 http://www.ussrphoto.com/UserContent/1712010_sonnarwartimef2ter.jpg
Stephan |
stephanvdz |
Posted - Jan 17 2010 : 3:29:57 PM and for your eyes only... a ZK that is not zeiss...
 http://www.ussrphoto.com/UserContent/1712010_ZK.jpg
 http://www.ussrphoto.com/UserContent/1712010_ZK1.jpg
 http://www.ussrphoto.com/UserContent/1712010_zk2.jpg
Stephan |
Jacques M. |
Posted - Jan 17 2010 : 3:22:14 PM Hi Stephan! Fine to see you back! The smell of Zeiss's lenses... In fact, I agree: it would be interesting to know more about the back of Alexander's ZK.
stephanvdz |
Posted - Jan 17 2010 : 2:36:52 PM  http://www.ussrphoto.com/UserContent/1712010_sonnarZKmount2.jpg
 http://www.ussrphoto.com/UserContent/1712010_sonnarZKmount4.jpg
Stephan |
stephanvdz |
Posted - Jan 17 2010 : 2:34:01 PM
 http://www.ussrphoto.com/UserContent/1712010_sonnarZKmount1.jpg
Stephan |
stephanvdz |
Posted - Jan 17 2010 : 2:31:41 PM the sonnar that looks like your zk...
 http://www.ussrphoto.com/UserContent/1712010_sonnarZKmount.jpg
Stephan |
stephanvdz |
Posted - Jan 16 2010 : 5:46:19 PM to see that... just take the back part of the lens out and look for a 6digit number...
Stephan |
stephanvdz |
Posted - Jan 16 2010 : 3:51:46 PM I've got almost the same lens with the same mount but in Carl Zeis Jena 2687429 T... thought at first that was an industar 26 mount with a sonnar barrel and glass.
I would be very interested to see the back of the mount... and if possible the zeiss serial number that is hidden in this lens...
Stephan |
RCCCUK |
Posted - Jan 10 2010 : 04:50:00 AM Hi Alexander,
The rigid 39mm screw mount version of the ZK seems to be rarer than the Kiev/Contax mount version. I have two versions of this lens with Kiev/Contax mount. One is a ZK of 1948 #000378 and the other is a ZK Zorki of 1949 #4903170. I also have a collapsible ZK Zorki 39mm screw mount lens of 1950 # 5001949. I do not know if the serial numbers are specific to the mount type, or whether all f/2 5cm lenses had one series of numbers. Perhaps someone with more knowledge of these lenses can let us know.
David
