 Need help with LILIPUT
fotomuda Posted - Aug 01 2011 : 3:11:30 PM
Hello!
First, the screw, that hold front plate, is missing. Can anyone make picture, what this screw is like and how is it fixed in the film chamber (pictures 1 and 2).
Second, theres must be missing one spring (picture 4). How does it look like and how fixed.
Thank you!
http://www.ussrphoto.com/UserContent/182011_lil1.jpg
http://www.ussrphoto.com/UserContent/182011_lil2.jpg
http://www.ussrphoto.com/UserContent/182011_lil3.jpg
http://www.ussrphoto.com/UserContent/182011_lil4.jpg
Vlad Posted - Aug 25 2011 : 7:34:08 PM
My pleasure, looks great!
fotomuda Posted - Aug 25 2011 : 04:11:04 AM
Thanks Vlad!!!
I have get the screw from smena-7 (from the top plate)
Vlad Posted - Aug 02 2011 : 8:27:12 PM
Unfortunately I wasn't able to take the spring out, it's coiled around a rivet and it doesn't seem to be removable. I took some detailed images instead. And there is no nut in the back.
http://www.ussrphoto.com/UserContent/282011_IMG_1252.jpg
http://www.ussrphoto.com/UserContent/282011_IMG_1253.jpg
http://www.ussrphoto.com/UserContent/282011_IMG_1255.jpg
fotomuda Posted - Aug 01 2011 : 11:00:22 PM
Thank you!
Pleas make one picture inside the film chamber!
I was thinking, is the screw fixed in the body or is ther somekind of nut there?
And dont you want to take of the spring and make a picture? With meausuring tape? (Dont risk if you are not sure, you can but it back :)
Best, Martti
Vlad Posted - Aug 01 2011 : 9:08:21 PM
It also seems that my Liliput has been repaired and the bigger diameter screw was put in, because I tried switching the screws around, the one from Maliutka (the original one) was too thin for the Liliput, but I think yours is just like Maliutka since I think whoever repaired it had put in a bigger screw..
Vlad Posted - Aug 01 2011 : 9:03:07 PM
Hi Martti!
I checked both my Liliput and Maliutka which has the same exact housing on the front, my Liliput doesn't seem to have an original screw in it but I took a picture of it anyways, but Maliutka does, so I think that's the screw that you should be looking for. See below.
http://www.ussrphoto.com/UserContent/182011_IMG_1244.JPG
http://www.ussrphoto.com/UserContent/182011_IMG_1245.JPG
http://www.ussrphoto.com/UserContent/182011_IMG_1246.JPG
http://www.ussrphoto.com/UserContent/182011_IMG_1247.JPG
http://www.ussrphoto.com/UserContent/182011_IMG_1248.JPG
http://www.ussrphoto.com/UserContent/182011_IMG_1249.JPG
http://www.ussrphoto.com/UserContent/182011_IMG_1250.JPG
Hope this helps. If you need any more pictures with different angles, let me know.
