Zenitar M2S 50/2 AKA Plastic Fantastic
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=1523
Printed on: 10/19/2026 12:16:30 PM
Topic author: aramaki
Posted on: 20100302121834
As you can imagine, this may be more of a users' than a collectors' issue. I have been very impressed by the general image quality of the Zenitar M2S 50mm f2 lens, as well as it's close focusing distance of approx. 0.35m (similar to the Pentacon 50mm f1.8). So much so that I have stocked up on three of them. However, it lacks an auto/manual switch, so I thought I might convert one of them for use on other bodies, like my Minolta XD7, or even my Pentax K100D DSLR. Has anyone tried to disable the aperture linkage on one of these, and if so is it fairly easy to do in a non-destructive way?
Kiev 88, Kiev 6c, many Zenits
Reply author: Poolhall
Replied on: 20100303092031
Yes it is, simply take off the bottom plate of the lens and put a sleeve over the pin to stop it poking through. This will keep it in the Manual mode, plastic wire insulation or a section of the plastic from a ctton bud stick will do. Or you can get an adapter with a flange on it that pushes up the pin, for Y/C mount and Pentax K at least. Try looking on MFlenses for Alex (HK300) he can supply adapters from Hong Kong at a decent price I have a K mount and a Y/C one. Yes it is a superb lens I have it in m42 and K mount and virtually always have either with me[:)]
Reply author: aramaki
Replied on: 20100304022703
Thanks Richard - I will give that a go... The DSLR I use is a Pentax K100D Super, but I have never found any K mount - M42 adaptors that have the flange, so I need to mechanically alter the lens.
