Zorki 5 problems
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=2745
Printed on: 11/7/2026 12:08:30 PM
Topic author: ichbinkaizoku
Posted on: 20141229122720
Hi, I just found out my parents had an old Zorki 5. The camera worked ( even though a bit rusty ) , the problem is I winded the film w/o the lens on not knowing this would be an issue. What can I do? How can I repair this camera? IS there a way? The lever that winds the film is now blocked, if I press the shutter nothing happens. This is such a nice camera and I want to restore it. :)
Thanks [:)]
Fed 2, Sony A58, Zorki 5
Reply author: Lenny
Replied on: 20141229174510
Please post the serial number of your Zorki-5.
Replied on: 20141229194923
Dear kaizoku
Zorki 5 ans Zorki 6 are good cameras but prone to the problem you described in all their series.
You must remove the top of the camera.
the locking of mechanics is due to a small subchassis where is mounted the gear responsible for reversing the action of the cranck advance.
This samll chassis is mantained in place by three screws.
When these screws loosen themselves the gear comes so tightly close to the two other ones that it is imposssible to make the mechanics roll.
The solution is relatively easy:
Discover that subchassis and get this gear far from the other two.
Retight the screws and the camera gets working again.
Now for a permanent repair, clean all the área with a lighter fluid and carefully loose the screws without moving the gear.
Glue the ares with a methachrilate and retight the screws
I will soon follow pictures of the procedure.
Regards and good luck.
Replied on: 20141229201829
correction are FOUR screws not THREE!
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/29122014_zorki 5 e 6.png
http://www.ussrphoto.com/UserContent/29122014_zorki 5 e 6.png
Replied on: 20141229202614
see also
http://ussrphoto.com/forum/topic.asp?TOPIC_ID=555
Reply author: ichbinkaizoku
Replied on: 20141230011220
If the serial number is ont he back of the camera, my number is 59099788 . The problem is I can't remove the top of the camera. The lever that winds the film is now blocked and I can't acces the screw under the lever. Is there a way to get that lever out or something?
Reply author: Lenny
Replied on: 20141230042136
Luiz is such an expert.
So it doesn't matter if you use a Zorki-5 or Zorki-6 without lens. It only depends on those 4 screws when they get loose. I wonder when this happened for the first time and if KMZ did something to prevent this in future, some paint on those 4 screws might be enough.
Reply author: Lenny
Replied on: 20141230080147
<blockquote id="quote"><font size="1" face="MS Trebuchet, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ichbinkaizoku</i>
<br />If the serial number is ont he back of the camera, my number is 59099788 . The problem is I can't remove the top of the camera. The lever that winds the film is now blocked and I can't acces the screw under the lever. Is there a way to get that lever out or something?
Thanks for your serial-number Kaizoku. When I watch the photo from Luiz it seems the whole button with the wind-lever is connected with the frame and those 4 screws. Try to push the whole button to the side and you might be able to wind.
Replied on: 20141230091017
<br /><blockquote id="quote"><font size="1" face="MS Trebuchet, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ichbinkaizoku</i>
Not a chance. [V]
Replied on: 20141230162631
Zoki 5 from first series ar easier to dismantle once you need no disassemble the rangefinder compensating prism
For didatic purposes Zorki 5 and 6 are the same differin only on the abssence of self timer and bottom loading construction on the model 5
Your Zorki 5 is from second series and equals to the model 6 in the top cap
This is th sequence of dismanling:
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/30122014_zorki 5 e 6 A.png
1 Unscrew the inner crown that holds the frame counter and surrounds the firng button
OBSERVE THIS IS A LEFT SCREW!!!!
THE THREAD IS REVERSE TO NORMAL SCREWS.
2 Remove the rangefinder compensating prism
this part is composed by three threaded -on parts Someetimes it comes complete some times dont
3 Remove the film reminder central screw on rewind knob
4 Loose two screws and remove the speed dial knob
5 With a a large screw driver fix the internal film forcket that engages on film spool and unscrew the rewind button the normal way.
6 remove two screws that holds the plateau of dipter correction lever.
7 the contacts are internally connected through small internal plugs
do not reverse them
A further operation must be done on the lever advance
the tutorial at
http://www.rangefinderforum.com/forums/showthread.php?t=45110
is very interesting and is a perfect guide for everyone.
Any doubts , please ask to us
http://www.ussrphoto.com/UserContent/30122014_zorki 5 e 6 A.png
Replied on: 20141230163243
The same layout is found on Zenit 3M
http://ussrphoto.com/forum/topic.asp?TOPIC_ID=1324
Replied on: 20141230164939
you cn see also
PDF downloadable manuals
http://www.uloz.to/xRBX8PH/i-s-mysenberg-ustroistvo-i-remont-fotoapparatov-pdf
I_S_Mysenberg_Ustroistvo_i_remont_fotoapparatov.pdf
http://www.uloz.to/x3Ua43S/m-f-yakovlev-remont-fotoapparatov-pdf
M_F_Yakovlev_Remont_fotoapparatov.pdf
http://www.uloz.to/xx5xdta/z-a-vishnevsky-remont-fotoapparatov-pdf
Z_A_Vishnevsky_Remont_fotoapparatov.pdf
Replied on: 20141230170124
more can be ssen at google's page
https://www.google.com.br/search?q=zenit+3m+repair&hl=pt&biw=1280&bih=607&tbm=isch&tbo=u&source=univ&sa=X&ei=Ni2jVJf9LIO-ggSfm4SYAg&ved=0CEwQsAQ#facrc=_&imgdii=_&imgrc=g6c5-wqvWZDoYM%253A%3BoNoCdZetqEqcSM%3Bhttp%253A%252F%252Fwww.rangefinderforum.com%252Fclassics%252Fforum%252Fmessages%252F20735%252F16571.jpg%3Bhttp%253A%252F%252Fwww.rangefinderforum.com%252Fclassics%252Fforum%252Fmessages%252F20735%252F16570.html%253F1254460212%3B400%3B267
Replied on: 20141231004424
I really thank you! You're so awesome! Thanks!
Replied on: 20141231075154
more on Zorki 5
http://aparatyanalogowe.pl/content/zorki/zorki-5-0
Regards and thanks
