Tair2 - FS2
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=3308
Printed on: 11/7/2026 2:30:42 PM
Topic author: Jacques M.
Posted on: 20180330153231
I have just bought a Tair 2 lens; one of those which were mounted on the wartime KMZ photosnipers.
My purpose is of course to take photos with that lens. For that, the first thing is to convert the 44mm screw mount into 39mm (or 42mm) to be mounted on a camera. But what about this 44mm screw? 44x1, 44x0,75, other? And does such a converter exist? I have not found any...
The second is to know precisely the distance between the lens and the film, through the original mirror cage. In other words, what is the thickness of this cage? It would greatly help to know that, if I want to put something like a Kilfitt/Novoflex/Visoflex between the lens and the body (which should be a Fed NKVD, of course!).
Thanks for your help![:)] Especially to the members who own a complete photosniper...
Reply author: Alex_Rus
Replied on: 20180331160924
https://www.zenitcamera.com/archive/lenses/tair-2.html
Replied on: 20180401045526
Many thanks, Alex.
So, as the seller told me it should be a 44mm, no doubt it's a M44x1 (and not a M46x0,75).
So, to obtain the M42 or M39, it seems that I only have the transitional solution of the T mount. I have not found any direct M44/M42 ring (or M44/M39).
So, it would be M44 female/T male, then T female/M42 male. No problem to obtain the M39 after, if necessary.
That would allow to mount the lens on my A7 to have the first trials.
Unless somebody has a better solution?
Replied on: 20180401155341
In fact, there are several solutions to go from M44 to M39... The most difficult is to find "something" in female M44!
To go further, I miss the thickness of the original photosniper mirror box. The original Visoflex I is 62,5mm thick; the FS2 one is visibly thicker ...
Reply author: Moxies
Replied on: 20180402082059
I use my later version (KOMZ) with KP A/M42 (T mount like), it works, but it doesn't feel safe, naturely.
Replied on: 20180402104231
Thanks, Pierre.
I allow myself to give the link to your photos made with a Tair:
http://pierretizien-photos.blogspot.fr/2014/11/fs-2-tair-2-30cm45-paris.html
I love these pastel tones.
Just to know: what is the overall length of your lens in order to shoot on your A7? If I understand zenitcamera, it's 270mm, probably up to the M44 mount only.
Replied on: 20180402161832
For those who are interested by this lens, an other link towards a very useful page:
http://lens-club.ru/lenses/item/c_4281.html
Finally, I have ordered a special M44x1 female/M39 male converter at Rafcamera's. Eager to receive and try all that!
Replied on: 20180423112003
So, I have received a good part of my puzzle.
The Tair 2 is there. A beautiful and strong lens, really very well made with an helicoid precise and without any wobbles. A converter ring, specially made by rafcameras: there is no normal F44x1mm/M39x1 available. And a Visoflex I.
Alexander K. had sent me the dimensions of his reflex cage (78mm thick). It largely helped me. Thanks!
First trial on a Fed NKVD. But the position of the camera is not right with the Visoflex I. I should turn the lens plate of c.15° because the mirror of the Visoflex does not turn with its ring. Impossible. So, I will buy a Visoflex II...
No problem on the Sony 7, except some vignetting on the corners.
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2342018_DSC00396.JPG
http://www.ussrphoto.com/UserContent/2342018_DSC00396.JPG
Perhaps it is the ring: 44/39 is quite "slopy". Anyway, another ring must be made as the actual one is 3,5mm too short to get infinity.
All that is encouraging, I think. I have ordered a "Dasco gunstock camera stabilizer" to try all the stuff... Sorry for the purists, the original FS2 will be for an other life!
Replied on: 20180423112633
Another photo (my neighbour's roof). The vignetting is well visible.
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2342018_DSC00392.JPG
http://www.ussrphoto.com/UserContent/2342018_DSC00392.JPG
Really, the lens is astonishing...
Replied on: 20180423113722
A pic lens/Viso/Sony. Uneasy to shoot with that...
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2342018_DSCF2674.JPG
http://www.ussrphoto.com/UserContent/2342018_DSCF2674.JPG
Replied on: 20180504144559
The Visoflex II is here. The new calculated 39mm/44mm is on the way.
I just have some problems with the stock: difficult to find one which fits correctly, because of the weight and the excentric balance. The Dasco I have received was broken, so I look for another solution. Probably I will have to adapt a "real" gunstock to my photographic purpose...
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/452018_DSCF2695.JPG
http://www.ussrphoto.com/UserContent/452018_DSCF2695.JPG
Replied on: 20180506145133
This vignetting is strange! I never noticed vignetting on mine, but I have only the "reedition" from 1963, not the "real" war-time FS-2, maybe that's why.
Replied on: 20180506154322
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/652018_DSC00402.JPG
http://www.ussrphoto.com/UserContent/652018_DSC00402.JPG
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/652018_DSC00403.JPG
http://www.ussrphoto.com/UserContent/652018_DSC00403.JPG
These ones are better... Always no correction, but taken on a sunny day. Less vignetting, as it seems.
The new converter will be 4,5mm more on the 44mm side. So, the narrow will be moved towards the Visoflex of this same distance. Perhaps it will change something, if the vignetting is mechanical?
Replied on: 20180527052659
Here is "my" photosniper. In fact, an international one, with a Ukrainian body, a Russian lens, a Belorussian converter, an English cradle. I don't know for the stock itself...
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2752018_IMG_0003.JPG
http://www.ussrphoto.com/UserContent/2752018_IMG_0003.JPG
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2752018_IMG_0006.JPG
http://www.ussrphoto.com/UserContent/2752018_IMG_0006.JPG
Replied on: 20180527053212
A heavy and steady item... To be perfectly usable, I must soften the release mechanism, much too stiff. And for the moment, I have to dismount all the mess to load the camera! Not very fast!
I will post some photos made with that photosniper when I receive the appropriate converter.
Replied on: 20180623115013
Two photos (recut: a shutter on my Fed is not in a good mood) made with "my" photosniper. Far from being perfect, but I am happy to see that infinity is there, on the first photo.
(Fuji film 200ASA, 1/60th, f 5,6).
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2362018_IMG_20180620_0001.jpg
http://www.ussrphoto.com/UserContent/2362018_IMG_20180620_0001.jpg
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2362018_IMG_20180620_0004.jpg
http://www.ussrphoto.com/UserContent/2362018_IMG_20180620_0004.jpg
Replied on: 20180726085955
I have changed the NKVD body: I have the choice...[:I]
A photo made with this new one.
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2672018_IMG_20180726_0007.jpg
http://www.ussrphoto.com/UserContent/2672018_IMG_20180726_0007.jpg
No more problem with the shutters, that time. Just a bit vignetting on the left. And I will have to check the register, not made on that body.
Replied on: 20180726143836
Another one.
http://www.ussrphoto.com/resize/resize_image.aspx?ImgWd=800&IptFl=/UserContent/2672018_IMG_20180726_0010.jpg
http://www.ussrphoto.com/UserContent/2672018_IMG_20180726_0010.jpg
Sorry, no artistic point of view. Only what I see from my office to infinity.
