The weird hammer-and-sickle FED
Topic URL: http://localhost:8088/modern/Forum/topic.asp?TOPIC_ID=3728
Printed on: 10/7/2026 6:25:13 PM
Topic author: uwittehh
Posted on: 20260707123153
I recently showed a photo of the Hammer-and-Sickle FED No. 3214. I was wondering why the shutter curtains were faulty – after all, I’ve had it for 15 years.
So I took it apart to repair it.
/UserContent2/772026_fed3214_01.jpg
When I took the cover off, what on earth was that? A Zorki cover! The ‘Zorki’ lettering had been stamped out and sanded down at the top.
/UserContent2/772026_fed3214_03.jpg
If you look closely at the top, you can still make out a sort of shadow of the ‘Zorki’ lettering.
/UserContent2/772026_fed3214_04.jpg
It is also strange that some parts were numbered. The shutter box and the housing have a ‘74’ scratched into them, and on the top, the ‘74’ has even been stamped in.
/UserContent2/772026_fed3214_06.jpg
/UserContent2/772026_fed3214_07.jpg
/UserContent2/772026_fed3214_08.jpg
The date scratched into the side of the case is also still visible, but in an unusual format: 7 - 8 - 5. Could this perhaps be 7 August 1955?
/UserContent2/772026_fed3214_09.jpg
Replied on: 20260707173938
And this is the result after reassembling it all :-)
/UserContent2/772026_fed3214_10.jpg
Replied on: 20260711030209
Interesting!It looks (a bit!) like the very early Kievs with Contax still stamped on the reverse of the front plate!
For you, the mechanism belongs to a Fed or a Zorki?
Replied on: 20260711150251
that was my first thought, too (Contax - Kiev) :-)
The camera is definitely a FED; only the top cover was taken from a Zorki.
I'm wondering what the “7 - 8 - 5” means. If it's 1955, then it would be a FED 1f or 1g; or maybe 1945.
