| Author |
Topic  |
Robert Vonk Fotohuis
Netherlands
100 Posts My Collection
Posted - Sep 07 2015 : 3:30:34 PM
F/4,0
F/8,0
F/16
Test film: Foma Retropan 320 Soft, E.I. 320 in HC-110 (B). Test cameras: Zorki-6, Leica M7 both with Metz 45 CL-3 on auto F/. Sync times resp. 1/30s - 1/50s. Split Grade optical prints and then scanned with my Epson V500.
Robert "De enige beperking in je fotografie ben je zelf" http://gallery.fotohuisrovo.nl/ http://www.flickr.com/photos/fotohuisrovo/ |
2667 Posts |
Posted - Sep 08 2015 : 07:40:53 AM
Thanks, Robert.
Could you say which photos are made with which lens? If I understand, you have used two couples, the M7+Summarit and the Zorki 6 + Jupiter for the comparison. Why not the M7 with a LTM/M ring for the Jup?
I would be very interested too by a daylight comparison, without flash, if it is possible.
Last: what are your conclusions?
Netherlands
Posted - Sep 08 2015 : 07:54:01 AM
The first is the F/2,0-85mm Jupiter, the second the Leica Summarit F/2,5-75mm.
You can read my mind .....
New setup:
With reflection screen and environmental light. I just found an adapter Leica LTM-M and used the new set up, linear in exposure from 1/1000s-1/2s with the M7 where the Schwarzschild effect of the Retropan 320 Soft film is starting.
The testfilm is already hanging to dry.
What you can see of above test photos: The J-9 is a bit softer on wide aperture but pretty close to the 20x more expensive Leica lens.
Netherlands
Posted - Sep 08 2015 : 08:04:53 AM
Just one of the first photos in practice with the J-9:
Also on Retropan 320 Soft. With the Z-6 and universal VF you have to watch out for the parallax correction of this 85mm lens. The closest range is 1,15m while the Summarit focus is up from 0,9m.
Netherlands
Netherlands
2667 Posts |
Posted - Sep 09 2015 : 07:44:34 AM
Yes, no doubt the difference is visible now. Even if the Jup has two small handicaps: the diaph wide open at f2 rather than 2,5 and the focal: 85mm against 75mm.
But I am a bit surprised by the wide open photo with the Jup. It doesn't fit my experience with such a lens. What is the serial number of this Jup? On the other hand, my 1950 Jup 9 is in fact a real Sonnar...
Thanks for the comparison. Jacques. |
Topic  |
